highboy wont shut off help!
thanks
The sparking when the cable is about to be attached means something is all set to draw current as soon as it can get it, and is arcing as soon as the cable gets close enough. My guess is the starter is what is drawing that much current.
If you take the 2 small wires and the large starter wire off the solenoid, you should be able to put a circuit tester there to see if the starter post on the solenoid is hot. If it is hot in that set-up with the key in off &/or run, it will be the solenoid for sure.
PS - I am not the best wiring guy. I can get 'er done, but there's lots of people that know way more than me.
-Nathan
Just pull the two small wires off of the starter solenoid on the fender. Now reconnect the battery. If after doing that the starter still tries to turn over, the solenoid is at fault. If not, continue on:
Reattach to the solenoid the small wires. If it starts trying to crank over, the ignition switch or wiring is at fault.
