Need INtake/water pump help
Old Mar 26, 2010 | 08:09 PM
mustang_gt_350's Avatar
mustang_gt_350
Alright i snagged a streetmaster intake about 5 or more years ago for a killer deal for my 360 project. Well the project kinda stopped as i got into truck pulling with my PSD. The interest in the FE is coming back and I have a problem = another pulling truck
On the intake right next to the thermostat housing is that small pipe/fitting that connects to the water pump with a short heater hose. Well my intake is missing that pipe. It appears that it is NOT tapped. So that brings up my question of is it supposed to be? and What is that thingy called that i can find one? lol Also if its not tapped i would guess its pressed in and that brings up the question of how much of a pain is that to do? Thats the only thing keeping me from filling it up with water and breaking it in. After thinking about it i guess i could measure it and tap it for an aftermarket fitting but I'm waiting for some advice first.
Thanks
Andy
Old Mar 26, 2010 | 08:55 PM
Bear 45/70's Avatar
Bear 45/70
It is a press in fit. But whenever I replace them I tap the hole and use a threaded fitting.
Old Mar 27, 2010 | 07:13 AM
mustang_gt_350
Do you know what size you tap it to? and a good place to buy the fitting?
Old Mar 27, 2010 | 12:55 PM
Argess's Avatar
Argess
NOt sure of the size, but typically you use a tapered pipe tap. The plumbing section guys at your local hardware store can give you guidance. Just take the piece of pipe with you, or buy a pre-threaded piece there.
Pipe goes by Inside Diameter, so a 3/8 pipe tap actually looks more than 1/2 in diameter.
You won't be able to flare the pipe end, but the hose can't go anywhere due to the water-pump, so it shouldn't be a worry.
Look around the plumbing section....there may be fittings that will work...galvanized, brass, etc., probably with barbed ends. I don't think the differeence in metals will cause any serious electrolytic corrosion problems. Most aluminum intakes use a steel tube, and although being a "no-no", nothing seems to happen to them.
Old Mar 28, 2010 | 03:40 AM
mustang_gt_350
Ok thanks for the help. I wasn't sure if i would just use any fitting or not. I'll have to look around in the plumbing sections.
