Remote Start Question
Old Mar 26, 2010 | 10:35 AM
TX Silver's Avatar
TX Silver
I think that my X might have a remote starter installed. There is a relay under the dash where the fuse box is located and there are a few wires spliced into the ignition harness.
Any way to tell if this is for a remote start?
That leads to my next question - If it is installed, is there any way I can just purchase the remote fob? The Truck only came with one key fob and it is the standard one.
Thanks for any help.
TX
Old Mar 26, 2010 | 11:14 AM
4X4X4RV's Avatar
4X4X4RV
Well best is to crawl up under the dash and see if you can read any info on the box, then if it is would be to find a remote and then programmed for the box/truck. If you had more than one remote you can program more remotes into the system/truck yourself, otherwise its off to the dealer.
also you need to find out if you have a chipped key (pats) and hope that the box is still programmed in the system.
I posted a pic of mine in my gallerytake a look it may help.
Old Mar 26, 2010 | 12:54 PM
TX Silver's Avatar
TX Silver
Thanks for the reply. I traced the wires from the relay and like I said earlier, some of them were spliced into ignition wires but the other ones terminated at a long white connector that is no longer connected to anything.
I think I might just leave well enough alone, the truck runs now an if I start messing with electrical stuff that might change
TX
kylebryan
Nov 19, 2012 11:15 AM
T REV
2004 - 2008 F150
Oct 31, 2009 02:29 PM
System
Oct 25, 2009 08:48 AM
wlsage
Mar 13, 2008 12:05 PM
