My clutch
Old Mar 25, 2010 | 08:37 PM
ybnrml_28's Avatar
ybnrml_28
My clutch
Hi (new to forums)
I have an 86 f250 6.9 4spd and seems happy, however sometimes (10%) of the time when i start from a stop i get a sound like i dunno, a really loud grinding or like dragging a chair across a floor sound coming from what i assume is my clutch. Still engages and pulls but the sound is loud, and painful.
Any ideas or experiences?
P.S truck is new to me but seems a bit sluggish. Have driven newer turbos, expecting too much i guess.
Old Mar 26, 2010 | 04:59 AM
Lazy K's Avatar
Lazy K
Can you clarify? Do you get the sound when the clutch pedal is first depressed and before you touch the shifter? Or do you get the sound with pedal depressed and when you are shifting into another gear?
As for performance a non turbo IDI will not come close to a Power Stroke.
Old Mar 26, 2010 | 10:09 AM
Dave Sponaugle's Avatar
Dave Sponaugle
If you get the noise when you push the clutch pedal down, throw out bearing would be my first guess.
If you get the noise when you are starting to move as you let the clutch out, U joints would be my first guess.
Old Mar 27, 2010 | 10:01 AM
ybnrml_28's Avatar
ybnrml_28
Clutch
Sorry about that the sound comes as i am letting the clutch out.
Old Mar 27, 2010 | 10:36 AM
starmilt's Avatar
starmilt
If the tranny is otherwise quiet, I will second Dave, also throw in tranny mount and or carrier bearing. The noise can also be comeing from the rear as sound will travel the driveline and fool you sometimes. Does it have any weird shakes or vibrations when taking off or any time.
Old Mar 27, 2010 | 04:01 PM
ybnrml_28's Avatar
ybnrml_28
Thanks for answering. there are no other weird shakes, vibrations or noises. it all is tight and quiet except for what i had mentioned.
kinda hoping it IS u joins tho....easy fix, but will look at what you mentioned before doing anything.
thanks
jps47
15
Sep 10, 2013 10:38 AM
Barndon
Aug 1, 2010 05:33 PM
Jaaaaaaackman
25
Oct 31, 2009 06:00 PM
1957F100
29
Sep 2, 2008 09:47 AM
reignman
Mar 15, 2007 08:53 PM
