P0380 Code
Old Mar 25, 2010 | 07:28 PM
sportsdad's Avatar
sportsdad
P0380 Code
Ok boys, I've been working on this problem for six months. I've searched and read and tested and searched and read and tested till I'm blue in the face. I can't find the cause.
I have a good GPR, I have good GPs, all my wiring checks good, all my tests show good voltage across all the circuits. Everything works ok. I still have P0380 to deal with.
Does anyone have a procedure for me to follow to find the answer.
I'm frustrated
I need to fix this problem so I can sell this beast. It's a great truck, I just own one too many.
Old Mar 25, 2010 | 11:26 PM
drivembig's Avatar
drivembig
Sounds like it could be the UVCWH. You could have one of the GPs shorting out. Even though it may ohm out ok it could be shorting. I would ohm them to ground and see what happens.
Old Mar 25, 2010 | 11:48 PM
sportsdad's Avatar
sportsdad
Already did. They are all at .1 ohm or slightly less
Old Mar 26, 2010 | 08:49 AM
sportsdad's Avatar
sportsdad
back to the top
Old Mar 26, 2010 | 09:06 AM
Jacksfirstdiesel's Avatar
Jacksfirstdiesel
have you cleared the codes since doing the work on your glow pllug circuit?
Old Mar 26, 2010 | 09:33 AM
Hussler's Avatar
Hussler
What year is your truck?
It's a Cali truck correct?
How long has this been going on?
Old Mar 26, 2010 | 10:43 AM
sportsdad's Avatar
sportsdad
Time line
-truck has been out of daily service since 2002 at about 180k miles.
-used as a parts runner for a couple of years
-I drive it every once and a while to keep batteries up and tires round for past 4 years
I noticed the light about 18 monts ago. Took to a "reputable" desiel garage. They put in a new GPR and said all is well. Got it home and on came the light next start up. Got the urge to sell the truck about a year ago. I've been working on the problem (when time permits) ever since. I've had a few other small things to fix and clean along the way also, but this is my last hurdle to putting a really clean truck on the market. A TRUCK WHICH WILL NEVER HAVE TO BE SMOGGED IN CA!
It's a 97 ordered in and purchased new in Cal.
Yes Jack, I've cleared the codes maybe..........45 times
Old Mar 26, 2010 | 08:20 PM
Jacksfirstdiesel
I know this must be frustrating. We will try to help.There is a real good sticky thread at the top on glow plug issues. keep after it- You'll get the best of it.
Old Mar 26, 2010 | 09:01 PM
Hussler's Avatar
Hussler
Code P0380 is not documented very well. I think it is indicating the PCM can't see main buss voltage from the GPR.
On the big metal strap you have three small wires that go back to the PCM.
1. One end of the bar monitors left bank current.
2. Center of strap monitors main buss voltage.
3. Other end of strap monitors right bank current.
All three of these wires are protected by (20 ga.) fuse links somewhere in the wire harness from the GPR to the PCM.
WAG, the #2 fuse link is blown. Sorry, I don't know how far up in the wiring harness those links are. I can give you pin numbers on the PCM connector to those wires if you want to try and ohm it out.
Old Mar 26, 2010 | 10:54 PM
Jacksfirstdiesel
could you bypass it with a jumper wire to test this idea out?
Old Mar 27, 2010 | 12:03 AM
sportsdad's Avatar
sportsdad
I'll try anything. I have not taken anything to a shop other than my own in years and when I did with this problem all I got was bupkiss. I'llkeep chasing if you guys keep the ideas coming. Thanks
Old Mar 28, 2010 | 12:49 AM
sportsdad's Avatar
sportsdad
bump
Old Mar 28, 2010 | 08:49 AM
MADVAN's Avatar
MADVAN
Replace the shunt bar.
Bill
Old Mar 28, 2010 | 12:21 PM
sportsdad's Avatar
sportsdad
Bill
Sounds doable
I'll run the three wires headed back to the PCM and check the fusable links. I'll track down a new shunt and try that if the wires check out.
Thanks guys, I'll let you know.
Old Apr 2, 2010 | 03:06 PM
sportsdad's Avatar
sportsdad
Back on it. I've been a little busy. Spring can be that way for a farmer.
Checked the wires, well, I checked the fusable links from the shunt to the wires that go to the PCM. They seem fine. I need a way to check at the test pin. Honestly, I don't know what that means. I know the test pins to check, but I dont know where they are in the system.
I also checked the shunt (I looked at it). How can this go bad? It is nothing more than a thin piece of metal that divides the current to each bank of glow plugs. The voltage is the same on either side.
Thanks for any help I can get.
