351M/400 issue
Old Mar 25, 2010 | 04:56 PM
AntiHero55's Avatar
AntiHero55
351M/400 issue
Hi i am new to cars/trucks and i just purchased a 78 f150 4x4 with a 351M/400 and auto trans.there is 2 things ive noticed with the engine so far.the first is when started and ideling the engine will lose power and die. how would i be able to fix this? the second problem is there is a slight knocking noise coming from the engine (around valve covers it sounds like) after the engine is shut off. the knocking will last for 1-3 min. what would that be and how could you fix it? or is the engine even any good?
thanks in advance!
Old Mar 25, 2010 | 08:06 PM
ctubutis's Avatar
ctubutis
If this happens whem it's cold outside and the engine hasn't been running in at least a
few hours, then I suspect the automatic choke might need adjusting.
If you're hearing a slight ticking noise after the engine is shut off, this is likely just the
engine components cooling off
Everything sounds like normal maintenance or behavior at this point, nothing abnormal.
F-ReV
Jun 9, 2014 10:45 AM
HoustonGuy
Jul 15, 2013 06:12 PM
rangel80
Dec 27, 2010 10:47 AM
Dale.Z
Jun 16, 2009 10:20 PM
Sunfire_Stomper
Sep 4, 2002 07:03 AM
