Will 4.10s help?
Old Mar 31, 2010 | 03:32 PM
  #31
Brojon2002's Avatar
Brojon2002
It sounds like the correct ratio for my needs are:
Turbo X 4.10 = uphill much faster
also know as
$$$$$ X $$ =
Old Apr 1, 2010 | 01:44 AM
  #32
peruses's Avatar
peruses
also know as
$$$$$ X $$ =
another option is the gear vendor overdrive, you can use the overdrive and second gear to put the motor right in the sweet spot
Old Apr 15, 2010 | 01:10 PM
  #33
Brojon2002's Avatar
Brojon2002
If I put in the 4.10 I would be turning about 2670 RPM? How does this sound for a towing RPM range? I "think" I'm at about 2310 now. This is all in 3rd gear.
I bring this up due to the fact I was able to talk my neighbor into help in the switch. I'm also thinking about 4.30 or 4.56. I just do not want to get stuck at the top of 3rd and the bottom of 4th.
What do you think or what have you changed to?
Old Apr 15, 2010 | 02:55 PM
  #34
timothyr's Avatar
timothyr
I personally am running 4.10's and think they are a good compromise for a rig that will be doing a moderate amount of towing....when I get all the bits to do my tranny swap (with double OD) I will be going to 4.30's....When I am pulling anything heavy (or with a high frontal load) I personally try to stay in the 2400 range on the flats, and closer to the 3k mark when on a hill....yeah she's screaming, but I have yet to have her drop below 45, and that was pulling a very decent grade while grossing near 20k
racsan
1983 - 2012 Ranger & B-Series
Feb 21, 2010 08:47 PM
mrad
Jun 18, 2009 03:00 PM
884x4broncoII
Mar 8, 2008 06:20 PM
bert stone
Jul 9, 2005 11:42 AM
Hoss Got a Cummins
Dec 25, 2003 02:45 PM
