Headlight conversion on an XL
So I have an '04 350 Dually. I was washing the salt off of the plow and framework during some well deserved warm weather this past weekend and noticed that one of my sealed beam headlights (Yes it's an XL) has a copious amount of moisture behind the lens. So I know that in the very near future, I will be freezing my **** off swapping a headlight.
What I started to think was it would be a great time to swap to an H13 or 9008 bulb.
I started looking on eBay and LMC Truck.
There are a fair number of options out there. What I would like to know is what you guys have replaced your headlights with, why and what you like and dislike about them.
Personally I want something bright. I mean REALLY bright. I am frequently on un-improved roadways in the dark and these ridiculous bulbs I have in here seriously cannot hold a candle to even my maglight. I also want something with a decent spread of light. focused projectors might not be all that appropriate for my needs. but either way.
lets hear, and if possible see what you have. Before I spend some good money on bad parts it's always nice to hear what someone else thinks.
Thanks for your information.
The headlights in my new XL dually seam to be a lot better than the ones that came with the '06, not sure if it is because they are jewel beam (or what ever they are called) or what.
I have kicked the idea around to change them out too with the SilverStar Ultra's, but I have caught wind that the factory headlight wiring may not handle the brighter headlights, but then again I don't know how true that is, as for the SilverStar high performance in the sealed beams it never was a problem for my '06 as they were in there for about 7 years with no problems.
SD Dually
SD Dually
SD Dually
If anyone has any insight on that one I would not be adverse to hearing it.
It may come down to just swapping out for better sealed beams if thats what it is to be. but the price of converting is not all that much higher. I see listings on eBay for aero style headlights all over the place.
http://www.ebay.com/itm/FORD-F250-F350-EXCURSION-CLEAR-BLACK-HEADLIGHTS-WHITE-LED-PARKING-LIGHTS-PAIR-/390761601299?pt=Motors_Car_Truck_Parts_Accessories&hash=item5afb34d913&vxp=mtr
or
New 99 00 01 02 03 04 F250 Super Duty Excursion Headlight Conversion HD Style | eBay
and LMC has a conversion kit that does not force me to change out the whole corner piece as well.
Aesthetics are not my biggest concern with this swap. I am looking for the most bang for my buck. I dont see me getting rid of this truck for at least another 5 years so my changes are to make it better to use. Lights are definitely one of the things I need to make better.
Thanks again.
I very much have the HID kits on the table. My concern with that is I remember reading somewhere that because I have a plow on the truck I may have the wrong harness through the plow system to do it???
Video Link: http://www.ebay.com/itm/FORD-F250-F350-EXCURSION-CLEAR-BLACK-HEADLIGHTS-WHITE-LED-PARKING-LIGHTS-PAIR-/390761601299?pt=Motors_Car_Truck_Parts_Accessories &hash=item5afb34d913&vxp=mtr
or
Thanks again.
for an improvement over your XL lights you could go with the one-piece replacements you listed, or get some 02-04 style composite housings that keep your current corner lights and blinkers like i think you also mentioned above. i put some on my '99 and it was a noticable improvement even over the composite 99-01 units that were on it.
https://www.ford-trucks.com/forums/1...1999-f350.html
I might be lost here on this but seems like heard somewhere thats how they hook up.
SD Dually
I am color blind and wiring is not a strong suite. So I tend to avoid it until I have an opportunity with a friend who is competent and not color stupid such as myself.
What brought this to light (all pun intended) is the moisture in my headlight. I know I am going to have to replace it (I do things when needed most of the time. Just dont have the heart to spend money on something just because I want to) so I figure this is a good time to look into it.
Originally I was looking at the ones at LMC that sit in the same brackets and look like a sealed beam. but then I started to think and wonder.
Being that it is an XL, I dont even have the luxury of fog / driving lights. I keep looking at ones to add, but again. I'm cheap.
Thanks again.
Of course no matter how I play that one the weather has to be just a LITTLE FREAKIN' WARMER!!! Argh!
and was there a lot of conversion to put these styles in ?
I bought my clears today need to buy bulbs tomorrow and connectors somewhere and one screw adjuster for the head assembly
thank you
Vince
Thank you I got the idea couple weeks ago to change out because I could not see the road well. I figured they would have something to adapt or change over. I'm going today to buy my ring clips for the bulbs at O'reillys though I do not know if they carry extra spare adjuster lamp screws one is missing on the ones I bought but for 60 for 2 assym that is not too bad of a deal.
thank you
I'll let ya know how it goes
Vince
