Holley carb help
Old Mar 24, 2010 | 08:55 PM
Black79's Avatar
Black79
Holley carb help
The fuel nozzle on one secondary barrel pours gas when the truck is running and drips until the bowl is dry when the truck is shut off. I havent took the carb off yet. Its a 600cfm elec. choke vac. secondary. Any ideas?
Old Mar 25, 2010 | 12:15 AM
brooklyn's Avatar
brooklyn
If it's the 80457-S, call Holley. Mine was recalled. If it's an 1850, I got nothin'.
Old Mar 25, 2010 | 09:29 AM
mark a.'s Avatar
mark a.
Check float level. Loosen the gas cap slowly so you can hear if there is psi building up in the tank.
Old Mar 25, 2010 | 05:42 PM
Black79's Avatar
Black79
I figured it out. My mechanical fuel pump was putting out 9 psi. I replaced it and that solved it.
crazyeddie
Aug 5, 2010 09:35 PM
harpoonjohnson
Feb 10, 2009 01:40 PM
lifted77f250
Apr 11, 2005 07:39 AM
illuminatrix
May 2, 2001 04:06 PM
