need some help with 1980
i have a 1980 ranger 150 with a 300 six, ive had this truck for over a year but have let my friend use it and he put a new holley carb, now its hard to start i think the choke warmer isnt connected right, it has a hard hose going to it from the exhaust but the other side is just capped off? would that cause a hard start problem?
i also think it needs new valve seals cuz exhaust is coming from the breather cap and so is alot of oil so maybe a new breather cap too
and the starter solenoid is also sparking and glowing red hot when trying to start it or crank it, now the + cable is super corroded, it has the 4 **** setup and wires(two black/yellow stripe, one solid yellow) are only connected to the + from the bat, + to the starter and the red/blue wire connected to the (s? i think) and nothing to the I
plz help me, if you need any info let me know its not at my house but im going back out there today to get more pics.. btw it does still run and strong just hard to start
sorry for the crappy pics
My guess would be number 1 & if that's the cases I'd replace the solenoid as well.
Whatever's causing all that shorting is going to be a huge draw on your battery voltage at cranking which will in turn make it harder to start. So this maybe your only tune up problem, or it could be just exaggerating a further issue.
starter
solenoid
alternator
carb
waterpump
fuel pump
distributor and complete tune up
valve cover gasket
oil pan gasket
also this was an a/c truck but the pump and hoses are gone from before i got it..
i tried to get the wires off the solenoid and it shattered so i went to pull a part to see if i could find another one and see how its supposed to be hooked up, no trucks out there had them but one and it was a 3 **** setup, no wires were connected, bit it was the only solenoid on any truck or van so i just grabbed it, im gunna try and hook it up tomorrow if it works good im gunna buy a new one
Hard to start the engine when it's cold or when it's warm?
Valve seals will not cause pressure and smoke from the engine breather. A improperly routed or non functioning PCV valve will cause this, and also worn rings in the engine. The valve seals will only cause smoke out of the tailpipe.
Always fix the obvious stuff first. That would be the corroded cable.
As for the wiring at the solenoid, the + from the bat, and all the little wires do go on that one side. The + to the starter on the other big terminal, and the red/blue for energizing the solenoid goes on the "S" terminal. The "I" terminal is normally not used for trucks with the DS2 (electronic) ignition.
Then look into replacing the PCV valve and making sure there is either a vented oil cap or one with a hose that runs to a filter of some sort. The PCV valve can't get rid of the fumes inside the engine it's plugged up.
I noticed the small chrome air cleaner, and can plainly see the carb vent is capped. That *should* be routed to the charcoal canister on the frame, near the battery.
i tried to get the wires off the solenoid and it shattered so i went to pull a part to see if i could find another one and see how its supposed to be hooked up, no trucks out there had them but one and it was a 3 **** setup, no wires were connected, bit it was the only solenoid on any truck or van so i just grabbed it, im gunna try and hook it up tomorrow if it works good im gunna buy a new one[/quote]
the three **** solenoid vs the four **** shouldnt affect the performance of the part. I have run into this with an 81 F100 Custom and an 81 F150 Ranger XLT, both with 300's. It seems that the parts supplier (melling in mine) made the four **** part for newer trucks and it is back compadible to the old three setup.
I am thinking that since you said the solenoid is glowing when you try to start it, that there is an excessive heat buildup in it. I am unsure of what would cause it, but it could be as simple as you got a bad solenoid. Also check that all of your cables and connections are proberly connected, and that there are no breaks in the insulation.
thanks for the info, its a vented breather cap it has about 10 holes on the under side, i cut the + cable down and the wire was nice and copper looking so i crimped a new lead to the end, cool i never knew about the charcol canister i thought it was for the a/c lol but what about the choke warmer? i noticed the one at the junk yard has a hard line from the exhaust pipe to the carb, mine has a hard line from the manifold to the carb and no place for a line too the pipe, it also has a straight pipe so you think it might be a back pressure problem? should i get a cheap cherry bomb or get a real eom type muffler,
this is not my daily driver just a camping/dump hauler rig, i was actually thinkin of selling it but i have more money into it than ill get back lol
ok thanks for the solenoid info!!! all the wires look old and dirty but none were cracked, also the + was straight from the batt to the solenoid, should i get a fuseable link on that??? maybe thats why its glowing red hot?
oh btw its always hard to start it cold or hot, im not sure the choke is working right, my friends uncle is ase certified and he adjusted everything and he knows way more than me about anything so im sure its hooked up correct the only thing im worried about was the warmer return line.. and now the line to the canister
i painted the engine over 1 year ago but i did it the bad way(didnt clean the oil all off just degreased and pressure washed it) so i mihgt pull the motor out and rebuild it and paint it nice and clean too
om sorry for all the edits, the canister is the thing on the passenger fender just in front of the a/c box?? and i connect the line in front next to the fuel line to it?
I doubt back pressure (or lack thereof) really has anything to do with any of the issues you described. The open pipe can lead to headaches, from both sound and fumes, if it's too short.
Adding a muffler really won't make much change it how it runs, unless it's a really restrictive type. It might make the cops and your neighbors a bit happier though. Even a cheap glasspack will tone down the sound quite a bit. I stuck a flowmaster 40 series muffler on mine, since I had a barely used one given to me. Free is a 4 letter word I like hearing......
also the thanks for the canister location, the line comes from the small fitting on the bottom? cuz i thought the big one on the top is to recirculate the heat for the choke?? not sure if i was right or not in thinkin that, or is there even a return for the choke at all?? also is the big one in the front of the carb fuel return and should i hook that up somewhere or leave it capped? i know the old small return line(i think looks like vac line connected to a hard line on the pass side frame and goes to the back) is cut off and sitting open with nothing blocking it off now
off topic, is there a way to lower these besides getting new ibeams? someone said i couls cut 2 1/2 coils out of the spring and thats the only way to do it.. and to flip the axle under the leaf springs.. doesnt sound too safe to me though..
Big port by the fuel line goes to the canister.
Small nipple at the top was the one that the choke tube started from.
Drop I-beams or spindles are the only way to lower the front, cutting the coils will leave the tires leaning, and no travel for bumps.
The small hard line isn't a fuel return, it's the tank vent. It also connects to the canister. There is no fuel return line on this application.
Addressing the choke heating line routing: the port highest on the carburetor and nearest the choke mechanism [presently capped] should have a rubber line which attaches to the heat tube end which you said is currently capped.
The choke mechanism housing [where the other end of the hard choke heating tube is currently attached] has a tiny internal port to the carburetor allowing vacuum to that area. This negative pressure sucks heated air [heated by contact with exhaust manifold] through the hard line to the choke mechanism which is controlled by a bi-metalic spring. The spring coils and uncoils based on changes in the temperature, thereby changing the position of the choke plate in the carburetor. In order for this to work properly, a source of replacement air must be present in the tube [hard line] or no air movement is possible. The replacement air must be clean [filtered] to prevent contamination. This source of filtered air is the port at the top of the carburetor throat. The air which is supplied has been filtered since it comes after passing through the air filter. There should be an insulative sleeve on the part of the tube from the exhaust manifold to the choke housing, but none is necessary from the carburetor to the other end of the tube.
wrong.the "I" terminal was use on the 460's with the hot fuel option with the dsII.the "I" terminal ran the intank fuel pumps while the engine cranks.
