Disassembling Overhead Console??
Old Apr 24, 2002 | 11:37 AM
Drawsoncad420's Avatar
Drawsoncad420
Im going to disassemble the overhead console to DynaMat. Has anyone ever pulled this thing apart?? This about the only thing i havent disassembled in the truck, and i would like a little input before i start. I just want to make sure im not going to get any wrinkles in the roof lining when i take it apart.
Thanks
Old Apr 24, 2002 | 12:33 PM
sneakerpimp's Avatar
sneakerpimp
Old Apr 25, 2002 | 11:56 AM
dvanhorn's Avatar
dvanhorn
Not sure if I understand correctly where you're going.
I've pulled down the console, in my case, to install a radio antenna.
Remove the single screw, in the eyeglass holder IIRC.
Pull the back down gently till it pops, then pull the front down.
Then slide the assembly forward to take it out of the retainers in the back. Two cables to unplug, and it's free.
I did not remove the mounting bracket, that looked more involved, and wasn't strictly necessary for my project.
I ended up using a Ryobi weed-eater blade to reinforce the antenna mount, as the roof metal is rather thin. Pictures are on-line at
http://www.inchase.org/outflow/events/installnic2002/installnic2002.html
Old Apr 25, 2002 | 12:12 PM
Drawsoncad420
ok, well thats all I really need then. When i get a good bass drop, I get a substantial rattle out of that compartment.I wanted to pack it with DynaMat, and i didnt want to disturb the roof lining. Well, it sounds easy enough...Thanks for the Info!
Old Oct 30, 2004 | 07:23 PM
aloonda's Avatar
aloonda
has anyone removed
their center console on an eb expy and put in the console from a f150?
i need some more leg room side to side and i am thinking of doing this
what is underneath the console towards the firewall? is it carpeted there?
if so, it shouldnt be that hard, otherwise i dont know what would go there
any ideas? suggestions?
Sian_Sam
May 28, 2025 11:07 PM
Benjemint
Mar 11, 2017 04:09 PM
jmurray101
Mar 19, 2014 09:41 PM
jbwilli
Jan 29, 2007 04:31 PM
buckcreek
Feb 24, 2005 08:16 AM
