Injector Pulse width
Old Mar 24, 2010 | 01:12 PM
utjer's Avatar
utjer
Was looking at some of the monitor parameters on my edge insight and found the injector pulse width. Does anyone know what is should be reading?
Old Mar 24, 2010 | 09:35 PM
william_04_x's Avatar
william_04_x
That's something interesting to look at. What kind of readings are you seeing and how is it affected by throttle input?
Old Mar 24, 2010 | 10:11 PM
PowerStrokeHD's Avatar
PowerStrokeHD
The fuel pulse width parameter is used to verify/monitor the fuel delivery signal while cranking the engine over. A 5 μs to 2 ms fuel pulse width is sent to the FICM if the system voltage is greater than 8 volts during cranking, engine cranking speed is above 100 RPM, ICP is above 3.5 MPa and is in sync.
Old Mar 24, 2010 | 10:41 PM
MoyockPowerstroke's Avatar
MoyockPowerstroke
I'm seeing around 1200 while on cruise control @ 60mph
dirkdriller
Jun 5, 2017 05:04 PM
jeepzj94
Feb 6, 2014 06:32 AM
FordMan35
Apr 13, 2011 09:28 PM
msteeler
Apr 4, 2011 05:20 PM
Aki_A
Jul 29, 2010 11:50 PM
