Factory tach install question
Old Apr 13, 2010 | 01:12 PM
  #91
Rogue_Wulff's Avatar
Rogue_Wulff
Since the tach is reading a bit low, ensure the "8" terminal is grounded. That terminal is to correct the reading for a V8, and is left ungrounded for a 6 cyl.
Old Apr 13, 2010 | 01:16 PM
  #92
TheKirbyMan's Avatar
TheKirbyMan
Huh, didn't think about that. I'd just check for continuity between the "8" terminal and a known good ground, correct?
Old Apr 13, 2010 | 01:18 PM
  #93
Rogue_Wulff
Yep. You can even just use a short jumper between the "8" and "G" on the back of the tach.
Old Apr 13, 2010 | 01:22 PM
  #94
TheKirbyMan
Would it hurt to leave it that way if it's in fact a ground issue? Or would it be best to run a new wire to ground?
Old Apr 13, 2010 | 01:26 PM
  #95
Rogue_Wulff
Either way will work. Less effort to make short wire with an eye on each end, and put it right on the tach. No need to disconnect it to pull the cluster....
Old Apr 13, 2010 | 01:35 PM
  #96
TheKirbyMan
Cool. I like the short-jumper idea, it'll save on wire and won't make the rat's-nest of wires under my dash any worse. lol.
I'll see what happens when I add this jumper and then I'll check back with the results.
Old Apr 13, 2010 | 03:00 PM
  #97
TheKirbyMan
Jumper is in place, and I don't notice much difference. It's spot-on at some speeds and a tiny bit off at others. But then again, it's a 25-30 year old tach, so can I really expect it to be as accurate as one that's only a few years old?
Old Apr 13, 2010 | 04:33 PM
  #98
Eddiec1564's Avatar
Eddiec1564
Is the tach bouncing around sometimes? The few 82 to 86 tachs I messed with had glue inside the tach that turns brown and causes all kinds of readings. In the the tech section there's a link about how to clean it up. https://www.ford-trucks.com/forums/7...dywhompus.html
As a side note, a few years ago(15 or so.??) I read up on a magizne about tachometers being accurite. They are NOT some of the times. The mag hooked up several tachs to one engine and showed they differed on average 100 to 300 RPM! The "only accurite" tach was a computer set up that measured RPM in the microseconds range.
Old Apr 13, 2010 | 09:27 PM
  #99
TheKirbyMan
It does seem to move just a tiny bit at sustained RPMs (doesn't matter what), but it's not bouncing. It moves maybe a millimeter or two, that's it. I do want to do like you did and clean off that glue, though. Doesn't it require disassembling the tach itself?
Well that would explain alot. I suppose it could be at least partially due to design differences.
Old Apr 13, 2010 | 10:11 PM
  #100
ctubutis's Avatar
ctubutis
The insides of a tach are delicate (these are semi-precise instruments). If you open yours up
(not real hard, I think all you hafta do is remove the 4 nuts) be careful with the insides.
Old Apr 14, 2010 | 03:36 PM
  #101
Eddiec1564's Avatar
Eddiec1564
The real worry is not to mess up the needle, dammage it and the tach is junk. The way these tachs come apart there is no need to mess with the needle at all. The pc board inside are pretty rugged as long as you don't over "pick" the brown/yellow glue out.
Old Apr 14, 2010 | 10:52 PM
  #102
ctubutis's Avatar
ctubutis
Exactly!!! The needle and the entire spring-loaded assembly that it connects to are
delicate assemblies; the PCB is pretty rugged.
Old Apr 15, 2010 | 01:06 PM
  #103
TheKirbyMan
I learned about that years ago...I was like 15 and I had removed the speedometer from a parts truck my dad and I bought....stupid me, I messed with the needle and ruined it. Those springs are like a slinky, kink it once and you're out of luck. lol
I got to thinking about it, and the tach seems to be working perfectly so far. I think I'll go ahead and leave it alone and not disassemble it. If it acts up later on, I'll clean off that glue.
Haven't gotten around to testing the circuit film for more breaks yet. I have noticed that my gas gauge is at least somewhat accurate. I think it gets flaky when I get close to empty. I'm guessing the sending unit might be to blame, since the gauge reads perfectly from about 1/4 tank up.
Old Apr 15, 2010 | 04:57 PM
  #104
81-F-150-Explorer's Avatar
81-F-150-Explorer
Very good advice on electronics.
If it isn't broke, don't fix it.
Routine maitenance is one thing, but that isn't routine...
Old Apr 15, 2010 | 05:27 PM
  #105
TheKirbyMan
Indeed. Got some experts here!
That's exactly what I thought. Plus I've removed the gauges like four times since I installed them, so I'm kinda getting tired of doing it over and over again...lol
