screen
Old Mar 24, 2010 | 08:17 AM
1_BIGMOFO's Avatar
1_BIGMOFO
screen
Im gathering all my parts and pieces for a full EGR Delete, new oil cooler, diesel site cooling filter system, fuel filters, air filter etc.......
can someone please tell me the part number of the screen under the oil cooler? Its the last piece I need.. I just called the dealer and they dont have any idea what i am talking about..
Any quick help would be appreciated..
Thanks,
Rob
Old Mar 24, 2010 | 08:59 AM
PowerStrokeHD's Avatar
PowerStrokeHD
IPR Screen/Filter: 3C3Z-6C683-AB
NOTE: This is the "updated" screen with the stainless steel mesh...
Old Mar 24, 2010 | 09:03 AM
1_BIGMOFO's Avatar
1_BIGMOFO
thanks a ton man!!!
Old Mar 24, 2010 | 09:05 AM
1_BIGMOFO's Avatar
1_BIGMOFO
sweet, they will have it in the morning... Thats the last thing I needed for my entire job!!!
I shoudl have it all now! If anyone has any other advice or tips im all ears
Thanks again
Old Mar 24, 2010 | 09:15 AM
PowerStrokeHD
If you have not done so already... This would be a good time to install the updated oil drain tube for the turbo...
Old Mar 24, 2010 | 09:16 AM
1_BIGMOFO's Avatar
1_BIGMOFO
I have not yet done so. is it a ford part? Do you have the part number and cost? Thanks a ton for the help.
Old Mar 24, 2010 | 09:21 AM
PowerStrokeHD
Yep, its a updated Ford part. The list price is $30.32. The part number is 6C3Z-9T515-A
Old Mar 24, 2010 | 09:26 AM
1_BIGMOFO's Avatar
1_BIGMOFO
cool man, thanks a ton! Is there anything else I should pick up from Ford while im doing this? I dont want to go overboard but im game to change things up for the better while they are out (to make things easier).
I also ordered the ICP sensor (they told me that mine is bad at the dealer)... The parts guy said he cant tell which one I have even with my vin #, he is telling me to buy 2 and return the one i dont use... Does that sound right to you? I also bought the updated plug / connector that they recommend..
Thanks again for the help!
Old Mar 24, 2010 | 09:32 AM
PowerStrokeHD
Is yours a late '04 with the ICP on the passenger valve cover or do you have a early '04 where it is back up under the turbo? This makes a difference while the pigtail is the same for both...
Old Mar 24, 2010 | 09:36 AM
1_BIGMOFO's Avatar
1_BIGMOFO
build date for the truck was 08.2003 but the truck is a 2004 6.0. Im not sure where the sensor is located yet..
Old Mar 24, 2010 | 09:45 AM
PowerStrokeHD
OK then... Late '04 production started 09/29/03, so you got a early one with the "fun" ICP sensor on the back of the motor. The nice thing for you is your turbo will be outta the way. The part number for the '03/early '04 ICP sensor is 3C3Z-9F838-EA and the pig tail is 5C3Z-12224-A.
Old Mar 24, 2010 | 09:49 AM
1_BIGMOFO's Avatar
1_BIGMOFO
im looking at my receipt from the dealer from yesterday (i paid for the sensor to be ordered and the pigtail is correct but the sensor is off 1 digit. This is what I bought, is it ok?
4c3z-9f838-a (your part number had an "ea" at the end)
is it the same part?
Thanks a TON for the help. This is very helpful and I am extremley grateful!!!
Old Mar 24, 2010 | 09:58 AM
PowerStrokeHD
Nope... You got yourself a late '04-up ICP. You need the other one..
Old Mar 24, 2010 | 10:00 AM
1_BIGMOFO's Avatar
1_BIGMOFO
ok, so the only difference in the part numbers is the "e"?
Anything else you can think I need or should do?
Old Mar 24, 2010 | 10:02 AM
1_BIGMOFO's Avatar
1_BIGMOFO
my build date was August, you said above August was an early build date. I just want to be clear on what one I need because im doing the job Friday night - Saturday and the dealers closed on the weekend so having the right stuff will be very beneficial
Thanks again
