my build date was August, you said above August was an early build date. I just want to be clear on what one I need because im doing the job Friday night - Saturday and the dealers closed on the weekend so having the right stuff will be very beneficial
Thanks again
Correct. "Late" build 04's started production on 09/29/03 and yours was built before that so you have a "early" '04. The guy at the parts counter should be able to pull up your "actual" build date using your VIN for confirmation...
ok, cool. Thanks man! Im calling the dealer right now! It would make things so much easier if they had someone that knew there stuff at the parts counter
