duraspark 2 help
Old Mar 23, 2010 | 11:51 PM
pro70golfer14's Avatar
pro70golfer14
duraspark 2 help
My friend has a 91 ranger with the 2.9 liter. This weekend we are pulling out his bad motor and putting a new one but it is carbed and he wants to keep it carbed. Everything else is worked out, but I need to know what one of the wires is hot in run that would be good to run the duraspark 2 module. thanks in advance. O ya could you be really specific on the wire so i can identify it easy.
Old Mar 31, 2010 | 12:27 AM
g_k50's Avatar
g_k50
Anyhelp out there for this low (no) reply orphan?
Old Mar 31, 2010 | 03:14 PM
wtroger's Avatar
wtroger
Your duraspark II module has a connector with a red and white wire white is hot run red is hot start. I would probably use the hot run wire that was powering the coil pack. I don't have the FSM with me so I can't give the wire location. You will also need to locate a hot in start.
1985tullyhowell
62
Feb 11, 2014 02:18 PM
RacinNdrummin
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Feb 1, 2005 07:40 PM
kf4lgeacj2
Aug 26, 2004 08:31 AM
moose4130
Jan 2, 2003 01:49 PM
