Aftermarket LSD/diffy?
Old Mar 23, 2010 | 07:38 PM
dhbmedic's Avatar
dhbmedic
I recently purchased a one-owner 2000 Expedition XLT 5.4L, 9.5 rear w/102K miles. After being assured (by the Chevy dealer) that the only sounds I heard from the drivetrain were "normal" sounds in 4WD when not in low-traction situations, I think I've got the rear-end LSD chatter problem.
I drained both front & rear diffs, refilled with the OEM recommended fluid & added friction modifier in the rear. The chatter was immediately reduced but is now back, about 400 miles or so later. After looking on this forum - and others - it sounds like I'll be having to replace the clutch packs or whatever.
For now I don't have any heavy duty driving applications, but I do plan on towing an RV in the next year or so. Are there any reputable aftermarket parts that I could use? Seems that since the OEM parts have been having trouble for several model years I'd want to stay away from them if I can.
Old Mar 24, 2010 | 07:44 AM
alwaysfords41's Avatar
alwaysfords41
Try another bottle of friction modifier before you go down the path to a rebuild. It could be a $5 solution for a $1000 problem. My dealership always uses two in higher mileage vehicles. It has worked fine in mine for the last 25k.
Old Jan 15, 2012 | 06:47 PM
dhbmedic's Avatar
dhbmedic
LSD/diffy Update
Now have a grand total of 139K on the Expy, not a single problem since the original flush-and-fill of front & rear differentials.
Got the RV last year, towed about 800 miles without a "hitch".
Glad I didn't go down the rebuild route!
Pool Runner
2009 - 2014 F150
Aug 11, 2013 09:48 PM
afonda
Dec 19, 2008 08:35 PM
NJF350SD
6.4L Power Stroke Diesel
Mar 27, 2008 03:53 PM
BURNSTOUGHFORD
1997 - 2003 F150
Oct 3, 2006 09:16 PM
true4.2
3.8 & 4.2L V6
20
Mar 16, 2004 09:12 AM
