97 F 150 Coolant in oil
1997 <nobr style="color: darkgreen; font-weight: normal; font-size: 100%; font-family: Verdana,sans-serif;" id="itxt_nobr_0_0">F-150</nobr> XLT
1FTDX1769VKA93920
4.6 V 8 Windsor Triton SOHC
Hello 1997 F 150, i drained the oil and it was like yogurt. I am wondering whether it could be the Lower intake manifold gasket or the cylinder head gasket.I dont see a oil cooler on the truck below the oil filter.
Also i had the drain plug off and when i pour coolant in the radiator it comes right out of the oil drain plug hole just pours right out of the drain plug hole. Is there any way i could make sure it is the lower intake or the head gasket.
Any advise will be much appreciated.
Thanks Mel
1FTDX1769VKA93920
Thanks Mel
Agreed....You might want to pull the Intake and look at the gasket condition.I suggest however that it is indeed time to pull the engine,and "go through it" if the water/oil issue hasnt been prevelant for long.Otherwise Id look into a long block,or a complete reman.......Welcome to the forum.
fireeater91
29
12-31-2019 03:05 PM
mrfox0246
17
05-26-2010 04:59 PM
boaterdude83
01-06-2010 09:03 PM
