1978 - 1996 Big Bronco
Ignition Problem
Old Mar 23, 2010 | 05:58 PM
dingeses's Avatar
dingeses
Ignition Problem
I have a 79 bronco when I am turning it over it will start firing and when I let go of the key it dies. New ignition switch, tumbler and solenoid. Need Help!!
Old Mar 23, 2010 | 06:13 PM
JBronco's Avatar
JBronco
Did you replace the actual ignition switch, which is located down on the steering column under the dash, or just where the key goes in? If not then that's your problem. If you did replace it are you sure that the rod is positioned properly?
Old Mar 23, 2010 | 06:48 PM
dingeses's Avatar
dingeses
I replaced the actual electric ignition switch in the dash that the key and tumbler goes into. Which rod position are you talking about?
Old Mar 23, 2010 | 07:31 PM
thecardoc's Avatar
thecardoc
79 Broncos don't have a column mounted switch or linkage rod either.
Being that you have already replaced the electrical part of the switch the most likely cause is the ballast resistor . This resistor is actually built into the wire from the ign switch to the coil and you can get at any parts store .
Old Mar 23, 2010 | 07:42 PM
dingeses's Avatar
dingeses
Thanks I'll use that for my wednesday stab at it.
Old Mar 24, 2010 | 02:51 PM
JBronco's Avatar
JBronco
Sorry I don't think that your year has the rod.
jdhudall
24
May 19, 2017 10:55 AM
mdbbrown
13
May 13, 2017 08:03 PM
Twite
Mar 16, 2017 06:55 AM
RAGaz
Sep 20, 2010 09:40 PM
Greywolfnsl
Apr 27, 2010 11:36 PM
