Aerostar Ford Aerostar
COOLANT GAUGE UP AND DOWN 4.0L
Old Mar 23, 2010 | 05:33 PM
99f350sd's Avatar
99f350sd
Guy's check this out. Never saw this..
http://ww2.justanswer.com/uploads/fo..._190204_A1.pdf
Also its not air or the thermostat that does it.. My white van is down 4" in the rad and the gauge is steady..
Just put a motorcraft thermostsat in my blue one and no change. Level is full, full..
Dick
Old Mar 24, 2010 | 09:29 AM
KhanTyranitar's Avatar
KhanTyranitar
Hmm, Thats an interesting TSB. If guess you might just need to do that.
Old Mar 24, 2010 | 09:33 AM
99f350sd's Avatar
99f350sd
Not for the price of the pump from the dealer though..I'll have to check around..
Dick
Old Mar 24, 2010 | 01:24 PM
Navyguns's Avatar
Navyguns
My gauge fluctuates frequently, but no thumping noises. I'll wait till the water pump fails, then replace it.
Old Mar 24, 2010 | 02:26 PM
99f350sd's Avatar
99f350sd
Same here.. The ford pump the tsb spec's out is discontinued..
Old Mar 24, 2010 | 11:12 PM
aerocolorado's Avatar
aerocolorado
How weird, in the recent past, I have had a really strange "percolation" (thumping) sound at times that I could never pin down. I did replace the pump (a rebuilt Motorcraft unit) with an aftermarket and the noise has not recurred.
Thanks for the TSB!
On edit: Here is the link to the strange percolation problem for future reference: https://www.ford-trucks.com/forums/7...ause-this.html
Old Mar 24, 2010 | 11:14 PM
99f350sd's Avatar
99f350sd
For Sure!.................
Old Mar 30, 2010 | 05:38 PM
jetfiremuck's Avatar
jetfiremuck
Ive noticed that if the engine is low on coolant to the extent that the sender is not in the coolant needing approx a half or more coolant to top the gauge still reads at the a in normal. This condition still happens after changing the sender and checking the gauge. This i think causes a lot of heads to crack including mine. Ive had to put a new head on the pass side. 4.0l.
Old Mar 30, 2010 | 05:46 PM
99f350sd's Avatar
99f350sd
Mine just goes from the N to the R and does it over and over.. Coolant is full..
Old Mar 31, 2010 | 08:27 PM
Aeroman59's Avatar
Aeroman59
Red face
Bad Thermostat, or bad water pump impellor? I had this exact symptom last fall, blew a heater hose because of it. I changed the t/stat & gauge is now rock steady. Engine now runs at 195* before it would travel up to 210/215 before opening.
Old Mar 31, 2010 | 09:24 PM
99f350sd's Avatar
99f350sd
I'm on the 3rd themo.. Now have the motorcraft one.. That ain't it. Either wp or gauge..i'm thinking..
Dick
Old Apr 1, 2010 | 05:13 AM
Aeroman59's Avatar
Aeroman59
Dick
Must be pump or possibly a partly blocked coolant line or passage?
Old Apr 1, 2010 | 03:32 PM
99f350sd's Avatar
99f350sd
Ok so listen to this: My wifes white van goes up to 177 deg and stays there rock solid..Its got a 190 deg thermostat new..Mine goes to 200 back down to 180 all day..
My wifes must not be closing I guess...I'll have to check my green van when I get it out of the garage. I think that one goes up and down a little...GRRRRRR
