just did a 3g upgrade
  #46
Old 07-15-2010, 09:11 AM
Blown 331's Avatar
Blown 331
Blown 331 is offline
This is a popular swap on 79-93 Mustangs (I have a few) but it had never even occured to me to do it on my truck.
Looks simple enough. I'll probably do the swap if mine fails but my truck has very basic electronics on it I'm thinking all that amperage really isn't needed. ?
  #47
Old 07-15-2010, 09:24 AM
akforceten's Avatar
akforceten
akforceten is offline
i wish i had known about this 7 years ago when i had to upgrade the charging system !!!! I bought one of those expensive powermaster 180amp alts from summit for $250 bucks it works good but i could have saved a bunch of coinage and had the same result . well when the powermaster gives up the ghost i will do the 3g!
  #48
Old 07-15-2010, 11:40 AM
79FordBlake's Avatar
79FordBlake
79FordBlake is offline
Originally Posted by jsutton
They both have two ears but the 130 amp only has 2 holes per set of holes where as the 90 amp 4 holes per set of holes. If that doesn't make since go back to page 1 and click on the link to the fullsize bronco page it has pics and everything of which is which and it has pics of the ones with the longer ears too. You want to make sure you get one with the shorter ears so you don't have to mod your mounting bracket any. Between the two threads you'll find out a list of cars to get them from, besides the Taurus are some 90's V6 T-birds and Cougars.
EDIT: As far as price goes my local U-Auto-Pull-It has them for $15.
Then you can just take it to Autozone and have it tested, hopefully your jy has a return policy for bad parts.
So from what I gather the alternator on the left is setup like what I need? And its a 130amp b/c there are two holes in the center of the case instead of four(90amps).
  #49
Old 07-15-2010, 11:41 AM
jsutton's Avatar
jsutton
jsutton is offline
Yep exactly.
  #50
Old 07-16-2010, 11:53 AM
emeraldcoupe's Avatar
emeraldcoupe
emeraldcoupe is offline
Originally Posted by 79FordBlake
How much is a good price for a 3G? I want the 130 amp one if I have a choice. Its the one with only two mounting ears correct? I don't want to give to much since there is a possibility it may be junk since it will be coming from a junkyard. Also wondering what I need to do with the electric choke on my Motorcraft since it won't work with the 3G?
Is there a certain vehicle I should look at getting one from besides a early 90's Taurus? Im going to be putting one on my 73 302 in the not so distant future. I have replaced the alternator twice, just put on another one two days ago and the cheap bearings are already squealing in it.
So sick of cheap china junk.
Is it easy to replace bearings, regulator, etc on the 3G? Thanks.
just ask for one off a 94-98 3.8 v-6 mustang or a 94-95 only gt.
  #51
Old 07-17-2010, 09:48 AM
RangerHaywood's Avatar
RangerHaywood
RangerHaywood is offline
No ones got any ideas about the electric choke?
  #52
Old 07-17-2010, 10:55 AM
AK FORD GUY's Avatar
AK FORD GUY
AK FORD GUY is offline
A few things I found:
"Factory Carb Users:
If you have a Factory Ford carburetor (Holley model 4180) with a wire that connects directly to your 1G alt to your electric choke, get a 12 volt electric choke for a Holley 4160, P/N 45-223, and swap it out. Then wire the new choke to 12 volts."
Holley Electric Choke Tuning - FordMuscle.com Forums
3G to electric choke - ClassicBroncos.com Forums
stator connection for electric choke - ClassicBroncos.com Forums
  #53
Old 07-17-2010, 03:54 PM
RangerHaywood
Ok, instead of blowing $50 on that, i heard i can take out the choke and run no choke. Will i be able to do that come -10* weather here in michigan?
  #54
Old 07-17-2010, 04:21 PM
LCAM-01XA's Avatar
LCAM-01XA
LCAM-01XA is offline
I highly doubt it, my experience with MI winters was that my 350 Chev fired up and idled beautifully on 80% choke, same with my 429 Ford except that one liked at least 40% choke even when warm from being recently run, if I skipped the choke on either when dead-cold I was just wasting my time and battery juice. A manual choke kit was around $10 at most parts stores last time I bought one (so a few years ago), it's probably the cheapest feasible option you have at this point.
  #55
Old 07-18-2010, 10:37 AM
Blown 331's Avatar
Blown 331
I've ran serveral carb'd engines all winter long for years with no choke and didnt have any probs. I'm near St. Louis and it gets down to 0 and below. At worse I'd pump it about 3 times, hit the key and they would fire right up, then maybe feather the pedal just slightly for 5 seconds to keep the accelerator pumps squirting, good to go after that.
  #56
Old 07-18-2010, 12:39 PM
LCAM-01XA's Avatar
LCAM-01XA
I dunno man, must be the nature of the individual beast - I did the three pumps and the 80% choke on the 350 every single time and it lit off immediately regardless of how cold it was outside, faster than most newer fuel-injected cars actually, with no choke she'd eventually still fire but it took a while. The 429 tho no way, heck that thing had an issue staying alive at idle in gear if the choke wasn't just quite right till it warmed up, I dunno if the 11.5:1 compression ratio had anything to do with it or not...
I'd say he should spend the $10 for the manual choke kit and install it now when it's nice outside, he may never really need to use it but that one time it's like -10 and he absolutely needs to go somewhere he'll have it at his disposal.
  #57
Old 07-18-2010, 05:46 PM
emeraldcoupe
for those looking for a 3g, here's a list of cars you can use one off.
130G Alternators:
94-96 Mustang 3.8 V-6
94-95 Mustang 5.0
94-96 Thunderbird 3.8 V-6 (non SC)
95-96 Windstar 3.0 V-6 (most are 3.8's)
93-96 E/F series Trucks/Vans 4.9 L6*
96 Sable 3.0 V-6
94-96 Cougar 3.8 V-6
  #58
Old 07-18-2010, 06:31 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
130G Alternators:
94-95 Mustang 5.0
96 Sable 3.0 V-6
You left off the most important and plentiful one of all... 90-95 Ford Taurus.
And also it's twin Mercury Sable 91-95
Josh
  #59
Old 07-19-2010, 01:37 PM
sdg0080's Avatar
sdg0080
sdg0080 is offline
if im not mistaken i think my 2000 stang has the same alt. it looks exactly like what i put on my 390
  #60
Old 07-28-2010, 09:48 PM
hevnbnd's Avatar
hevnbnd
hevnbnd is offline
Originally Posted by vtjvt
The only thing I did differant than the diagram was instead of running the yellow wire back to the solenoid I just looped it over to the B+ post on the alt.
Anything wrong with doing this?
Quick Reply: just did a 3g upgrade
