My uncle got a 4.2 in pieces on the back of the truck. A 1997 F-150 2wheel, auto. What engines are compatible with the wiring harness and computer?
What would the$$$ be on buying a used 4.6.
Is it a big deal to swap out to an eight and still use the same wiring and stuff.
Not into the computer cars , give me a carb any day.
This is for a friend and you guy's are more up on the new stuff than me.
Help if you can.
Thanks
I hear ya on the carb'd truck but there are only so many dinosaurs and dinosaur lovers around to keep them alive. Long live the dinosaur!My insuranse company gets confused when i tell the the the year of my vehicles,...try renting a car dolly or trailer from U-Haul....Ï'm sorry , did you say the vehicle thät will be towing is a 1977? ....
Any ways back to your question....
the 4.2 and 4.6 are "Modular" engines, so the bell housing pattern is the same , a 4.6 will bolt in. The easy part ends there. Computer and harness are different. Best to find a donnor truck for the swap or look for another 4.2 V6.
My friend has a 4.6 "'97 2wd, I have changed the tranny, most of the wear and tear stuff including a front coil spring. Took me almost 3hrs to change the #4 spark plug and the better part of a day to do the heater core.
They are a good truck to DRIVE, can't say that they're a good truck to work on.
good luck with it!
Frank
