Sponsored by: Auxito
Downsizing wheels size
Old Mar 21, 2010 | 09:47 PM
darkmage55's Avatar
darkmage55
Hey all, i do some offroading with my 01 f150 4x4 and it has the stock 17 inch rims. Since these are a less common size when it comes to offroading, i was wondering if downsizing rim sizes would have any negative effects. I would only go to 16" or 15" if i could find some with the same lug pattern. Ive heard of it being bad as far as the front disks. Any inputs? Thanks.
Old Mar 22, 2010 | 11:21 AM
gtiguy's Avatar
gtiguy
you can as long as the breaks fit i have 16's on my truck and i know i cant go smaller.
the only other way you can go smaller would be to get rims the have a crazy offset so they will stick out of your truck like a mother!
Old Mar 22, 2010 | 02:00 PM
darkmage55's Avatar
darkmage55
ill prolly just go to 16's. thanks gtiguy
Old Mar 22, 2010 | 05:51 PM
steve(ill)'s Avatar
steve(ill)
try to keep the OD of the tire the same if you want the speedo to work right. lets say you have 265 x 70 x17 now... if you go to 16 inch rims and dont want to go wider than 265, you might try to find 75 series tires instead of 70. ----the older 3/4 tons had 235 x 80 x 16 which are tall and narrow--- that might work.
Old Mar 22, 2010 | 06:02 PM
darkmage55's Avatar
darkmage55
im gonna try to get wider wheels, i like the look and the added traction will be nice
Old Mar 22, 2010 | 06:23 PM
redwood's Avatar
redwood
My truck came with 265/75-17 (I think) on 17" wheels. The tires were later changed to a 33x12.50-17 and the torsion bars cranked a bit in the front. I ended up going to a 16x10 rim and a 305/70-16 tire and it fits fine. The tires stick out just hair, and the rims are just big enough to clear the brake calipers.
Old Mar 22, 2010 | 08:51 PM
darkmage55's Avatar
darkmage55
Redwood, do you have any pictures of just how far the tires stick out? Tryin to get an idea of what i want to do.
Old Mar 22, 2010 | 10:40 PM
redwood's Avatar
redwood
These tires are 305/70-16 and are equivalent to a 33x12.50-16. This is the closest pic I have of a profile. If you need a better one, let me know and I'll snap one tomorrow...
Old Mar 23, 2010 | 09:09 PM
darkmage55's Avatar
darkmage55
that pic will do, thanks redwood
jlstorm
Jul 27, 2022 10:37 PM
rdog1
Apr 30, 2017 05:54 PM
OleLogger
New Member Introductions
Aug 16, 2014 09:52 PM
martin72
18
May 22, 2014 07:51 PM
clintusaf
32
Feb 2, 2013 07:07 PM
