Sponsored by: Real Truck
better gas millage????!!!
Old Mar 21, 2010 | 03:39 PM
05 minirig's Avatar
05 minirig
im new to this site can anyone help me? I just bought an 05 350 crew cab dually. i currantly get about 11-14mpg......awfull i would like to see closer to 20mpg can anybody tell me what i should do...i currantly have everything stock on the truck.
Old Mar 21, 2010 | 03:50 PM
rbaker6336's Avatar
rbaker6336
What engine and drive train do you have
I may be wrong but to get 20mpg you might have to push it some
Old Mar 21, 2010 | 03:59 PM
05 minirig's Avatar
05 minirig
i have the 6.0
Old Mar 21, 2010 | 04:09 PM
05 minirig's Avatar
05 minirig
i herd one guy says he gets close to 19....what would be realalistic to see that truck get?
Old Mar 21, 2010 | 04:12 PM
driximus's Avatar
driximus
do you have anything done to your truck. Exhaust and tuner will help make sure you get some gauges with the tuner. other then that is the same as any other vehicle, correct air pressure in the tires, dont be mashing the go peddle everywhere. I keep mine at 1800-1900 rpms cruising.
Other then that having a dually your gonna be behind the power curve those extra tires are gonna eat some MPG's with the extra weight of the crewcab also is gonna hurt your MPG.
Old Mar 21, 2010 | 04:19 PM
rbaker6336's Avatar
rbaker6336
Realistic milage,around town about 14
On the open road depending on the speed you run from 14 to 17 1/2
Old Mar 21, 2010 | 04:22 PM
05 minirig's Avatar
05 minirig
hows this sound? cut the cat converter off straight pipe,programer and a cold air intake/
Old Mar 21, 2010 | 04:30 PM
TennesseeMustangPerf's Avatar
Drive downhill.
Sorry. Congrats on the new truck! Bad thing is that 14-15 is about your average, that is what I see too (2003 F-350 crew cab 4X4 6.0L). Biggest thing you can do to increase mileage is to adjust your driving habits. Also proper service is key not only to extend the life of the truck but also a tank of gas. Keep the truck serviced properly and keep the tires inflated correctly. Wish there were better news, if you find a way to make 17-20MPG please let me know.
Old Mar 21, 2010 | 08:10 PM
sandmanf250's Avatar
sandmanf250
03 6.0 3.73 gears single rear wheel sweet runnig 6.0 with 166000 miles. shell rotella t 5w40 oil. 17.80 on the road ,and about 15.5 in town.best truck i've ever had.
