Sponsored by: Auxito
99 f150 "shutter?
Old Mar 21, 2010 | 12:00 PM
princess1969's Avatar
princess1969
Question 99 f150 "shutter?
Hi everyone! Have a question on my dad`s truck. When you start it, it seems to shake quite a bit with no power until it warms up. Doesn`t really do it when it`s warm out & there isn`t any engine light on? Any clue on what would cause this? thanks guys!
Old Mar 21, 2010 | 01:23 PM
Ron W.'s Avatar
Ron W.
Any codes?
Last tune up?
Have a scan tool that shows pid's?
no suggestion at this time
Old Mar 21, 2010 | 01:40 PM
steve(ill)'s Avatar
steve(ill)
"normally" it is a bad coil, and "normally" it will eventually set off a code to tell you which cylinder.......AFter you start it up, start driving while it is still missing. Usually you will get a code if the miss is long enough time frame, and large enough in magnitude.
