Sponsored by: Real Truck
no Hazards
Old Mar 20, 2010 | 05:35 PM
BobbyDiesel71's Avatar
BobbyDiesel71
no Hazards
Apparently, my Hazards aren't working
I don't drive truck everyday and will look for bad fuse
Just seeing if anyone else has had this issue
truck died last Sunday night and I tried to turn them on, no luck.
Truck is running fine and I have tail lights/all marker lights and headlights.
Does a Hazard switch ever gone bad??
Old Mar 20, 2010 | 07:37 PM
FireMe's Avatar
FireMe
Check fuse 18 under the dash. If it's OK, then remove the column trim and check to see if you have power at the white with red wire at the multifunction switch.
If you have power, it is probably a bad switch.
If you don't have power, either there is a harness problem or the flasher relay is bad.
Jay
Old Mar 27, 2010 | 10:57 PM
BobbyDiesel71
thanks
I did replace fuse 18, worked reat for a few days, blew fuse again today.
UGH I am going to diagnose problem tomorrow!
Padra
Jun 13, 2012 10:10 PM
BuckHammer
15
Mar 11, 2011 07:51 AM
dinikin
21
Nov 4, 2007 01:34 PM
pedrorairez
23
Jan 22, 2007 09:21 PM
nucleartruck
Electrical Systems/Wiring
Apr 25, 2004 08:48 PM
