changing ball joints
Old Mar 20, 2010 | 04:01 PM
ohmar99's Avatar
ohmar99
anybody have a link on changing out ball joints on my 94 F250 4wd. Thanks
Old Mar 20, 2010 | 05:53 PM
RCrawler's Avatar
RCrawler
Do you need the complete rundown starting at removing the tires? Or just removing the knuckles and replacing the ball joints?
Jason
Old Mar 21, 2010 | 03:19 AM
LCAM-01XA's Avatar
LCAM-01XA
Oull wheels, pull calipers off knuckles, hang calipers on frame, take locking hubs apart, remove wheel hub retaining nut and pull hub off spindle, remove 5 big nut holding spindle to knuckle and beat spindle off, pull axle shaft off, then finally get medieval with the BJs. Reassemble in reverse order. This would be a good time to install new front brake rotors.
Old Mar 21, 2010 | 05:15 AM
Lazy K's Avatar
Lazy K
https://www.ford-trucks.com/forums/9...-u-joints.html Here you go.
