Sponsored by: Real Truck
stock radio needed.
Old Mar 20, 2010 | 01:03 PM
tjc transport's Avatar
tjc transport
i ain't rite
stock radio needed.
does anyone have a stock radio/cassette player laying around they don't need??
after chasing a battery draining short in my fathers crown vic for 5 months, i have determined through a process of elimination the radio is the culprit.
i came to this conclusion after putting a test light in line with the pos battery wire, and started pulling fuses.
when i pulled the radio fuse, the light went out.
the radio works fine, but something inside must be bad, and drains the battery dead in 3 days.
Old Mar 20, 2010 | 01:45 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
What model and year truck?
Old Mar 20, 2010 | 06:04 PM
tjc transport
i ain't rite
it is going into a 99 crown vic, but i know a cassette/radio from a 99-03 superduty will work.
Old Mar 21, 2010 | 01:19 PM
GFfirema83's Avatar
GFfirema83
i have a factory radio outa my 01 f250 superduty
Old Mar 21, 2010 | 02:08 PM
Rongold's Avatar
Rongold
Talking RADIO
If you can't find one, check Ebay---there are usually plenty of them on there. I don't thing a radio from a super duty will fit properly---the SD dash is vertical---the CV dash, I believe, is slanted.
RON
Old Mar 21, 2010 | 06:32 PM
scottzj's Avatar
scottzj
Hangin 10 bra
I have the 6 disc changer in dash from my 04 King Ranch that I will be selling in the near future. I just got my new radio in sat, so planning on installing it really soon.
Old Mar 21, 2010 | 07:00 PM
2002 F350V10's Avatar
2002 F350V10
Superduty radios are different and do not fit. The crown vic, just like the 97-03 F150 trucks use a radio where the top of the radio drops down to clear inner dash braces. The sd radios are like a rectangle box and are too large without major cutting of the dash bracing. If you want a working radio, pm me, or e mail me as I have the old one from my 02 F150 which is a factory am fm cassette, since I swapped it out for a cd radio. Ill send it to you for $20 shipping included. Bill
Old Mar 21, 2010 | 07:15 PM
dkf's Avatar
dkf
Thats how my old stock CD player in my 04' f-250 is, your info is not completely correct.. This is what the stocker looks like that came out of my 04'. http://cgi.ebay.com/ebaymotors/Ford-...fAudioQ5fVideo
Old Mar 21, 2010 | 07:23 PM
tjc transport
i ain't rite
yup. the superduty single cd and cassette are single DIN radios. it is the CD/cassette and multi disc players that are double DIN.
and the CD/cassette was not an option in the CV/GM/lincoln until they changed the defroster ducts in 03 to accept the double DIN radios.
i have a radio with single CD player in my 99 P-71 that i took out of my 02 F250 when i put the CD/cassette player in
Old Mar 21, 2010 | 08:25 PM
2002 F350V10
The part number for the radio you linked on starts 4L2 which means this
4=2004, L2=ford explorer
You could read the part numbers with this link.
Reading Ford Motor Company Part Numbers
By the way, I had bought a new 02 F350 back in 02, and at that time ford did not offer a single cd radio for an 02. There were 3 choices . The xl had an am fm, and an xlt had an am fm cassette /cd and then the high end radio was an am fm 6 cd radio. Your single cd radio never came factory installed in an 02 sd as far as I know.
I also have an 05 crown vic and the dash requires the radio with the notch to clear the dash braces still.
Old Mar 21, 2010 | 08:30 PM
dkf's Avatar
dkf
The link was just for a picture reference to what I had. I bought my 04' new and pulled the OE radio myself and still have it.
I think 2004 was the switchover for the single CD player on the SD. My dads 03' came with the CD/Cassette, 6 disc was the only other option. Fords always changing stuff.
Old Mar 22, 2010 | 01:51 AM
redford's Avatar
redford
FTE Leadership Emeritus
The radios do draw some current while they are off. That is normal.
I would not declare the radio to be bad just yet. Did you measure how much current it draws? Was the battery tested to see if it is holding a charge? Was the charging system checked to see if it is charging the battery OK?
Old Mar 22, 2010 | 06:23 AM
tjc transport
i ain't rite
i bought the 02 used, so i don't know what it came with.
it had the single CD in it when i got it
Old Mar 22, 2010 | 06:29 AM
tjc transport
i ain't rite
i know that
yup. .950 amps with the ignition shut off.
nope. it is new
yup. all the charging system tests were done multiple times over the past 9 months since the battery started dying every 4th day.
i even went as far as to buy a new battery to keep charged in the garage so i could just swap out the dead battery.
if the car is used every day, it will go a week to 10 days before the battery is dead. but just sitting only lasts 3-4 days.
since i unplugged the radio, it has sat for 2 weeks now and started rite up on saturday.
Old Mar 22, 2010 | 06:36 AM
SGnAZ's Avatar
SGnAZ
This will fit in a crown vic?
