6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
repair time??
Old Mar 19, 2010 | 05:08 PM
BTXpress's Avatar
BTXpress
repair time??
I will try to add more later, but...
How long to replace CAC/intercooler, change oil and filter and both fuel filters?
3 days is seeming a bit excessive, especially since they did not have to order any parts.
BT
Montgomery, Al
Old Mar 19, 2010 | 06:14 PM
StanleyZ's Avatar
StanleyZ
BT
Montgomery, Al
Mine took about 2 or 3 hours at the dealers.
Old Mar 19, 2010 | 07:15 PM
senix's Avatar
senix
you can do the filters and oil in about 1 hour taking your time. CAC is really pretty simple if they have it...it is right there in front! About the only thing simple on the truck.
Old Mar 19, 2010 | 09:20 PM
cheezit's Avatar
cheezit
I owudl think about a half of a day in total shop time. it would only take 2 hours to do.
Old Mar 19, 2010 | 10:15 PM
LaxPlaya21's Avatar
LaxPlaya21
Union time or actual time?
Old Mar 19, 2010 | 10:18 PM
cheezit's Avatar
cheezit
no we just like to make you guys sit in a waiting room and pace back and forth. after all we stuck there till 5pm.
Old Mar 20, 2010 | 08:39 AM
69cj's Avatar
69cj
I thought it was so they could grt rid of the left over morning coffee.
Old Mar 21, 2010 | 03:24 PM
fg250's Avatar
fg250
O.K. speaking of CAC's, I opened my hood this morning and saw a light film of oil on/around the boot that connects the pipe to the cooler itself. Is this something to concerned about? And why would there be oil up there anyway?
Old Mar 21, 2010 | 03:27 PM
cheezit's Avatar
cheezit
first off check your engine oil level.
next you can remove the lower cac hose at the cac side and pull it back make sure no oil is in the cac.
its not uncommon to have a small amout of oil on the boots. it is bad to have excessive oil in the cac itself. excessive oil in the cac is caused by excessive engine oil levels, excessive oil level in the crankcase is knowen as oil growth in a 6.4 this happens from the engine regen process.
Old Mar 21, 2010 | 06:20 PM
senix's Avatar
senix
So my guess the fix for this oil in the CAC would be a proper oil level and then try to clean any oil out of the cac you can.
Old Mar 21, 2010 | 07:01 PM
fg250's Avatar
fg250
thanks for the help, cheez it. I pulled the lower hose off and no oil ran out. I also checked the engine oil level and it's right to the max line, maybe VERY liitle over, kind of hard to tell, it seems like the reading is higher on one side of the dipstick than the other.(maybe just smudging when I pull it out.) but I wiped the oil film off the boots and will keep an eye on it. I've got about 1500 miles left on this oil. While I was at it I drained the water trap also.(got about 2 tablespoons of water) bought the truck in late January and haven't drained it until today.
Old Mar 21, 2010 | 07:12 PM
cheezit's Avatar
cheezit
you really gotta watch the water in the wif. water is a big issue and like to kill the hpp.
Old Mar 22, 2010 | 01:29 AM
senix's Avatar
senix
use the short stick method to check your oil, need to do it after it sits for a long period. I also make a habit of checking mine weekly.
After you change the oil, short stick it and get a good baseline for where it should read.
Old Mar 22, 2010 | 07:57 PM
fg250's Avatar
fg250
Please explain the short stick method, I'm unfamiliar with that one.
Old Mar 22, 2010 | 08:00 PM
cheezit's Avatar
cheezit
put the stick in to the bottom of the yellow part were it is even with the tube.
