Sponsored by: Real Truck
08 TT mirrors
Old Mar 19, 2010 | 03:26 PM
cowboy69911's Avatar
cowboy69911
08 TT mirrors
Can you put the TT mirrors off a 08 super duty on a 2000 super duty? Will they just bolt up or is there a mod you have to do?
Old Mar 19, 2010 | 03:47 PM
Lubbockguy1979's Avatar
Lubbockguy1979
The 08-10 mirrors are a direct bolt on. The wiring though is different. The 08's have heat, power fold and power telescope. The 04-07 trucks came with heated but not the telescope or fold option. You will have to run power and switches to get those options
Old Mar 19, 2010 | 04:14 PM
cowboy69911
Did you put them on yours? If so did you run the new power also?
Old Mar 19, 2010 | 04:15 PM
SteveH-CO's Avatar
SteveH-CO
How much does an Aftermarket or OEM Ford set of '08+ mirrors run? I presume they are black (and not body-color coded).
Thanks!
Old Mar 19, 2010 | 05:11 PM
89CrewCab's Avatar
89CrewCab
There are no aftermarket '08 TT mirrors.
Ed the Parts guy sells them at a good price, compared to list:
Power adjust, manual extend, lighted: Power mirrors
Manual adjust, manual extend, no lights: Manual mirrors
I'm thinking about just going with the manual mirrors
Old Mar 19, 2010 | 05:22 PM
cowboy69911
Thank you for all the info and help!!!!
Old Mar 19, 2010 | 07:02 PM
Lubbockguy1979
Have put them on. I'd like to though. Dfuser sells them with switches for the telescope and fold feature for I think $700-800. Personally I doubt ill get them if they cost that much. Way out of my price range. I could get half a turbo or 3 injectors for that kind of loot
Old Mar 19, 2010 | 09:26 PM
Din's Avatar
Din
i put a set of power fold 08 mirros on my 06 you have to splice into the factory mirror harness into the door as well as run additonal switches and power to make the power fold , telescope function to work.. You also have to grind off a little tab on the newer mirros.
Old Mar 19, 2010 | 09:38 PM
TennesseeMustangPerf's Avatar
Can you post a schematic of the wiring?
Old Mar 19, 2010 | 11:28 PM
cowboy69911
So there around 700 each or total for both? I am looking cause I just had one of mine hit and it broke the lens and some of the case.
Old Mar 20, 2010 | 03:36 PM
Din's Avatar
Din
ive been selling these sets new $900 shipped. I just sold 2 sets this past weekend. They retail from dealer for around 700-900 a piece.
Old Mar 20, 2010 | 07:41 PM
cowboy69911
Hey din can you pm me your info and stuff I might get some from you
Old Mar 20, 2010 | 11:28 PM
wallz's Avatar
wallz
There is enough people that have done this now and the info is on fte to wire them up yourself and save a little from having to get the complete set with the switches.
My switches ran $5-8 a piece and then a little wire and soldering kit, and connectors/heat shrink. The bigger investment is in the mirrors themselves and then a few hours to wire them, again depending what you had stock.
The 09 and up mirrors now run heat on both the upper and lower mirror, and yes, you can get them color coded.
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
Old Mar 21, 2010 | 11:35 AM
Any chance in the future of making a retrofit kit that allows us pre-2008 guys to install the power folding mirrors/power telescoping features on our existing mirrors? I would love to do this, but can't spend quite that much on something I won't use all that much.
Old Mar 22, 2010 | 04:06 PM
Din's Avatar
Din
Its not that hard installing a set of pre 08 model. I installed a set on my 06 took about 1.5-2 hours to do the wiring. The hardest part is running the extra wires to the doors to make the power fold function work. Other than that just add the swtiches.
THose that inquire about mirrors please send me an email dpham06@yahoo.com
