no key for door locks.
Old Mar 19, 2010 | 01:15 AM
fordinmudd's Avatar
fordinmudd
Question no key for door locks.
I bought a used 96 f 350 4x4 the guy had a key for the ignition but no key for the door locks I really cant understand why. I guess he put in a new ignition since you need 2 keys but why would he not keep the old key?doesn't everyone know the new key wont fit the door .anyway the truck was in such good shape I bought it but I cant go anyplace yet cause I need new door locks.how much would new door locks run?is that what there even called if I have to order them from a ford dealer?and how much money would it run me?or can I get a locksmith to make me a key?I'm really not sure.strange though I looked at 2 used trucks that both had the same issue a key to start it but no key for the door locks.any info will help thanks.
Old Mar 19, 2010 | 01:37 AM
White 97 xlt's Avatar
White 97 xlt
You could go to a locksmith, but it might be cheaper to go to NAPA and get a set of door lock cylinders, I think they still have them.. That way they are new and should last many more years.
Old Mar 19, 2010 | 01:50 AM
zxwut?'s Avatar
zxwut?
A locksmith can cut you one.
Old Mar 19, 2010 | 01:58 AM
crusem's Avatar
crusem
Before you buy new door locks try squirting some lube in the key hole. I thought I had the same problem with my new 97 F250 but went to the lock smith first. He said it is a common Ford thing and squirted a little lube in and the key started working. He didn't charge me anything but he gained a customer.
Old Mar 19, 2010 | 02:15 AM
fordinmudd's Avatar
fordinmudd
thanks everyone.Ill see what I can do.great answers helped me alot.
Old Mar 19, 2010 | 09:18 AM
FordPickMeUp's Avatar
FordPickMeUp
you can get the door lock cylinders online there only $35 eash and come with 2 keys.That would be the cheapest way.A locksmith will hit you up for 200 for a key.
Old Mar 19, 2010 | 10:05 AM
Jbotto's Avatar
Jbotto
Before I bought my current truck, I was looking at a 95 that didn't have the keys. I checked around and salvage yards wanted like 10-15 bucks apiece for new lock cylinders. I remember a Ford dealership wanted 90 dollars for the set of them. I think you could pick them up for cheaper at NAPA or O'Reilly's.
Old Mar 19, 2010 | 10:25 AM
danr1's Avatar
danr1
I think you're missing the point "crusem" was trying to get across, and maybe failing at, these trucks do not have separate door and ignition keys, the ignition key is the key for the door lock.
Not sure of the exact year they changed it, my 87 has a ignition and door keys both yea but my 94 and 95 have only one key for everything.
Use some liquid wrench or WD-40, stick the tube right inside the lock and flush the shi_ out of the locks with it.
The PO probably never locked the doors so the locks have froze up some. Shouldn't take much at all to free them up.
Old Mar 19, 2010 | 11:52 AM
crusem's Avatar
crusem
Thanks darn1 you said what I was trying to.
Old Mar 19, 2010 | 12:04 PM
zxwut?'s Avatar
zxwut?
Then why did you say you think he changed the ignition so you needed separate keys for the locks and ignition?....
Old Mar 19, 2010 | 12:32 PM
ichabod40's Avatar
ichabod40
I had the same problem with my truck. I priced the new cylinders at O'Reilly's for $90 for the pair. The local locksmith only wanted $25 to cut me two keys.
Old Mar 19, 2010 | 08:24 PM
skyfox10's Avatar
skyfox10
why don't you go to a dealer and give them proof of ownership and the vin? They can cut an original key that will kit your door.
Old Mar 19, 2010 | 10:35 PM
RustyGreen's Avatar
RustyGreen
FYI... I checked into my door locks when I got my truck and these years of trucks is past what the dealer can look up in the computer to code a new key to your locks. I removed the locks and had the locks smith make me two keys for them and it was only $35 total for him to do it.
yitzy
Aerostar
Apr 6, 2013 11:51 PM
cardone
Feb 5, 2013 02:58 PM
DEMIGOD
Sep 11, 2011 08:57 PM
JD Dixon
May 20, 2010 08:13 AM
nemesis2005gt
1978 - 1996 Big Bronco
Mar 12, 2007 05:17 AM
