Removing parking/turn lights
Old Mar 18, 2010 | 09:43 PM
aero993's Avatar
aero993
I found the two screws that hold the park/turn signal light assembly. But, it seems as though something is still holding the light assembly. Am I missing something, why does it seem stuck?
TIA,
Anthony
Old Mar 19, 2010 | 06:58 AM
jdw1's Avatar
jdw1
Look in the owners manual if you have one, they just pull out towards the front of the truck after the two screws are removed. On my 2000 X the wiring is short so be careful not to damage the harness, you can open the hood and see the wiring go through the bulkhead to the light fixture.
Old Mar 19, 2010 | 07:28 AM
vettman80's Avatar
vettman80
turn signal
there is a pin holding the light in place open the hood and use a flash light you can see it mine was so stuck i had to use a long flat screw driver to help pry it from the back side
Old Mar 19, 2010 | 08:45 AM
aero993's Avatar
aero993
I finally got it off, I had to impose my will on it this morning.
Thanks
abranz
Nov 16, 2014 01:07 AM
Anthony Koertner
Oct 18, 2012 03:41 PM
aero993
Mar 10, 2010 02:46 PM
aero993
Feb 5, 2010 11:11 AM
adamant
Aug 19, 2003 10:25 PM
