Sponsored by: Real Truck
wheel backspacing for 16x8
Old Mar 18, 2010 | 01:28 AM
ford7379trucks's Avatar
ford7379trucks
I did a search but they were all on larger rims. I want to install a set of American Racing Outlaw lls 16x8 with 5.5" backspacing. just want to know these wont rub.
thanks
Old Mar 19, 2010 | 04:32 AM
high ho silver's Avatar
high ho silver
thanks
since you have leaf springs on yours I would recommend 4.5" backspacing due to rubbing issues when you turn lock to lock with the 5.5". Plus you would probably have to remove the rotor protective shield on the left rear because it would probably rub against the inside of that wheel.
Old Mar 19, 2010 | 11:34 AM
ford7379trucks
ok thanks then the outlawIIs wont work because they only come in 5.5" spacing.
Old Mar 19, 2010 | 06:24 PM
khxor's Avatar
khxor
Americanracing.com lists it as 0 Offset, 4.5"BS. I find it very common to see mistakes on sites when looking at wheel specs so it's a good idea to check a whole bunch. Not sure where you looked but Summit for example lists +25 offset, 5.5"BS, they probably goofed and used the spec for the 16X8 6X139.7 bolt pattern.
Old Mar 19, 2010 | 07:09 PM
ford7379trucks
ya summit is were i looked. thanks
FordF100man
Nov 7, 2015 01:52 PM
Pepinbilt
May 12, 2015 08:48 AM
hav24wheel
Dec 1, 2013 12:15 PM
whiteisright
Jan 21, 2012 02:20 PM
76 crew
Apr 13, 2007 08:59 PM
