81 3 speed auto
Old Mar 17, 2010 | 11:42 PM
truckerboy's Avatar
truckerboy
81 3 speed auto
I am lookin into an 81 F150, it has a 300 c.i. and a three speed auto (c4 or c6, idk yet). I wanna know how this trucks trans. will hold up, and what kinda milage its gunna get.
I think that it has 2.25 gears, but thats just a guess.
Old Mar 19, 2010 | 12:09 AM
85e150's Avatar
85e150
C4, C5 or C6. Id here, also found up top under "articles/specs"
Ford Transmission Spotter's Guide .: Articles
Old Mar 20, 2010 | 01:20 PM
truckerboy's Avatar
truckerboy
it appears to have a c6.
Old Mar 20, 2010 | 02:21 PM
Rogue_Wulff's Avatar
Rogue_Wulff
The C6 is a tough old trans. With a 300, C6 and 2.75 gears, I can get 16-18 MPG on the highway. It isn't fast by any means, but it does have decent pickup when accelerating.
I haven't seen any 2.25 gears used behind a 300 C6 combo, but that doesn't mean it never existed. Most have 2.47, 2.75, or 3.00 gears in 81. 3.25 and 3.50 are possibilities, but no where near as common.
Old Mar 20, 2010 | 05:30 PM
truckerboy's Avatar
truckerboy
i was just guessing at the gears.
So... this should be a pretty sound truck??
Old Mar 20, 2010 | 05:33 PM
85e150's Avatar
85e150
If you have a 9" rear axle, the 300/c6/9" are three of the strongest components ever fielded by Ford.
I can't recall the variants on your vintage truck. Do you have 5 on 5.5 bolt pattern wheels?
Old Mar 20, 2010 | 05:35 PM
truckerboy's Avatar
truckerboy
yep, 15" w/ 5 on 5.5.
What i sthe towing max on this setup? I could pull 8000 on my k1500, and want to use this truck to pull the same trailer.
Old Mar 20, 2010 | 05:53 PM
85e150's Avatar
85e150
Not sure of the factory spec, but that seems like a lot given the 300 and the gear you are running. You'll move it, but not too fast or quick... and you'll be in second a lot with any hill action.
And don't forget trailer brakes....
Someone may have better info on the specs or direct experience with that combo....
Old Mar 20, 2010 | 05:58 PM
truckerboy's Avatar
truckerboy
its just around town, 2 hills max and 25-35 mph. should handle it with trailer brakes.
Old Mar 20, 2010 | 06:11 PM
85e150's Avatar
85e150
For that duty, you're all set.
Good luck with it.
Old Mar 20, 2010 | 07:27 PM
truckerboy's Avatar
truckerboy
thanks for the help.
I will finally get the truck tuesday at 1800 hours. (ill get pics in then)
