Replacing low pressure pump on a 89 460
Old Mar 17, 2010 | 08:05 PM
Mudman's Avatar
Mudman
I am building a new wheeler using a cab and chassis frame and motor from a 89 F-Superduty. I am going to use the factory fuel system. The problem is I do not have room for the front tank and only want to run the rear tank which I don't have. I came across a cab and chassis tank with a regular sending unit. Can I mount a aftermarket low pressure pump on the frame? If so, what pressure and cfm does it need?
