Got all 5 of mine for $25 with factory wire harness. NEW in box. From a guy that bought them and then sold his truck and never installed the lights. I was originally looking for smoke. But ran across these.. Bought them in October/November and i remind myself i have them every time i sit at my desk. I kick the box.. Then i remember i need to mount these when the weather breaks.
Hey Dan the kit that you have comes with a wiring harness. So that means there is no wire splicing? I was aslo thinking of putting a set of cab lights on my 01. Is there a difference between the factory lights and the recon set besides the price?
Yes no splicing, as long as you get the right harness. There is a different harness for the models with the overhead console and the ones without. The plug is behind the passenger side kick panel.
You can check out one of my galleries. I have lots of pics on my install. You can also search and find the thread from when I did mine. There are a few issues that came up with the wiring because i had the harness for the trucks without the console, but i have the console. It wasn't hard to fix the issue though. I had my buddy do the drilling though. I couldn't bring myself to drill holes in the roof of my truck.
If you need the template I do have one I can send you. Has the measurements as to where to center the lights, and the template to mark the holes.
I couldn't drill sober though. I taped it up and marked it, measured about 5 times and went to drill and hesitated. Had to sit down with about 2 beers then I did it, lol. After the first hole the anxiety goes away.
As for the harness, I have the overhead console. Ran the wiring down the passenger A pillar and zip tied it to the existing harness. Found the plug in the passenger kick panel but didn't fit. I found the correct wire to turn the lights on with (it was in the plug but nothing attached to that specific terminal. I was about to cut the wire and just make a splice when Jim came over and stopped me. I removed the terminals out of the cab light harness plug (only 2, one + and one ground) and threw that plug away. Then I just simply put the new wires in the existing OE plug where they would have been if it was factory.
Jason. I checked out your your pictures.. Awsome. Looks easy enough. Didn't look like you pulled you head liner out.. that is the scary part. I will have to look at how they come out. Snap.Clips?
Thanks for the info Keith. I don't think i will need template. I will wing it..
My harness has the plug on the end. I hope it works and I also hope my truck has a connector. that would be sweet to have the plug behind the kick panel and my lights just plug in. No center overhead console.
Roger.. I go the lights off a guy that bought everything separate. So i don't know if it was a kit or not or were he purchased them from. I would suspect he got everything from ford.
Harness Number 1C3T-15A404-AA x1 ford
Light Number 8C3Z-15442-C Amber x5 ford
Jason is your cab lights ford or after market? I want to put cab lights on my truck and Iwas looking at recon. Iam wondering if the ford is cheaper. I like the looks of the smoke lens that recon has. Is there a different kit for over head console?
The plug is a standard thing on all the trucks. They don't know if that harness is going in a truck that has cab lights or an overhead console so everybody gets one just in case.
I come up with two part nos. for the roof lamps: 6C3Z-15442-A and 8C3Z-15442-C.
The latter is marked "Made In China" which does not thrill me. Is the former made in USA?
