what is it
Old Mar 17, 2010 | 03:53 PM
slamin79's Avatar
slamin79
what is it
what is this called it needs new bushings,, i need to know what its called
Old Mar 17, 2010 | 04:00 PM
berry1234's Avatar
berry1234
Radius Arm. The bushings are not expensive.
Old Mar 17, 2010 | 04:41 PM
slamin79's Avatar
slamin79
thanks,,,, are they a bi*&^ to change
Old Mar 17, 2010 | 05:03 PM
berry1234's Avatar
berry1234
Nah. Just unbolt the bracket remove the big nut and put it back. If there is a rivet instead of a bolt, cut it out, then put back a bolt at least grade 5 or above. Jack up the front and take the pressure off the arm with a floor jack.
Old Mar 17, 2010 | 08:33 PM
slamin79's Avatar
slamin79
zzzzzzzzzzzzzzzzzzzzzzz
all you have to do is unbolt the nut off the back of the radius arm, use a comealong and attach one end to the front framerail and the other to the hole in the radius arm and pull the whole arm out of the bracket. after the arm is out of the mount, put on the new bushings. use plenty of lube on the bushings. always use poly bushings. they may squeek a little but they don't wear out. then push on the end of the arm with your feet while a friend slowly releases the comealong. put the rear bushing on the back of the arm and tighten the nut down with a big breaker bar.
is this true
Old Mar 17, 2010 | 09:27 PM
pidaster's Avatar
pidaster
is this true
Doesn't sound so good.
Old Mar 17, 2010 | 09:47 PM
Hickfied's Avatar
Hickfied
is this true
Watch your shock and steering for bending. Never tried it so I don't know but it sounds like it may work.
Old Mar 17, 2010 | 10:29 PM
frogy_pw's Avatar
frogy_pw
Info about a truck
Hello I am on this site to find out about a truck that i have you might be able to help me find out more info well here is what i have it is a 1974 ford 1 ton with a huge cab it has a fouton couch in the back the driver and passenger seats are captains chairs and they swivel the top of the cab rises above the front seats about 6 inches or so there are windows there that you can see out of it is a really cool looking truck and i've only seen 1 other one like it if you could help me find out more about it i would really apreciate it i am waiting on the pics then i could send you a pic my E mail is frogy_pw@yahoo.com THANK YOU for your help.
Old Mar 18, 2010 | 12:41 AM
starmilt's Avatar
starmilt
Yes it's true, and the easiest way to change them.
Froggy does your rig have a van front or a regular pickup hood.
Old Mar 18, 2010 | 12:50 AM
HillbillyDeluxe81's Avatar
HillbillyDeluxe81
....I don't think you can do it that way if you have lift coils and stock radius arm brackets.
Old Mar 18, 2010 | 06:25 AM
bucks77ford's Avatar
bucks77ford
Old Mar 18, 2010 | 06:52 AM
Redneckryder's Avatar
Redneckryder
Nothin like a random post out of the blue.....first and only post so far......hmmmm
Old Mar 18, 2010 | 07:27 AM
460/5's Avatar
460/5
Zombie Survivalist
that comealong idea doesnt really sound like the best idea to me...
Old Mar 18, 2010 | 07:35 AM
460/5's Avatar
460/5
Zombie Survivalist
hi frogy! welcome to !! you would get a LOT more assistance with your question if you posted a new thread instead of postin a reply in an existin thread. if the photos are on like photobucket or some place like that, you can just post a link to them, OR right click on the image, go to "view image", and then the image should show up on the screen by itself. copy the URL, then go to the "go advanced" reply button, or if youre makin a new thread you wont have to. got to the toolbar at the top and there is a little insert image buttion that looks like a miniature postcard with mountains on it. past the URL in the pop-up box and be sure the http:// is only in there once. then when you post your pictures will be there. hope you get it figured out!
Old Mar 18, 2010 | 07:36 AM
460/5's Avatar
460/5
Zombie Survivalist
woops!! double post! that hasnt happened in a while...
