noise when towing
I’ve been told it could be the low octane fuel causing the noise but I’ve also been told not to run the high octane fuel in my truck.
Is either true and could this be causing damage to the engine? If so how can I fix it?
Thanks for any help you can give.
You are perfectly alright to run premium. Most people say you don't NEED to run premium since most engines do just fine with regular. But if you are getting pinging, switch to premium or that mid grade and see if the problem goes away. Premium will not hurt your engine, it just may be a waste of money if you don;t need it.
Why do you think the oil companies make all those adds saying "give your car a treat with premium"? They certainly would not do it if it hurt due to liability. But they know it doesn't hurt and they get an extra 20 cents or so per gallon, sweet for them.
My 94F250 460 runs great on regular, but if I tow especially in hot weather or hills it will ping. So I use premuium or mid grade when I need to.
Good Luck,
Jim Henderson
I hope just moving up to mid grade will eliminate the pinging. If it doesn't, you may want to talk to your Ford service about it. Reason I say that is, ignition timing is supposed to advance with higher engine speed. But at WOT or low manifold vacuum the computer is supposed to retard the timing to prevent ping while climbing hills or towing.
Scott
If it takes expensive gas to make it quit, it'll still be cheaper than replacing the engine when you burn thru a piston or overheat it.
