OT, help with front mudflaps
Old Mar 17, 2010 | 09:41 AM
whitesdford's Avatar
whitesdford
Im trying to find some front mud flaps for my truck, but im not finding any. I need some that have stainless trim on them to match the rears, anyone have a good starting point to start looking?
Old Mar 17, 2010 | 10:32 AM
DieselCamper01's Avatar
DieselCamper01
No help here but I will provide a bump for you
Old Mar 17, 2010 | 10:34 AM
allen03's Avatar
allen03
saw them on ebay a while back
Old Mar 17, 2010 | 11:37 AM
itsjustdan26's Avatar
itsjustdan26
Give McCandless a call. They may have something in stock for ya.
Old Mar 17, 2010 | 11:41 AM
snakedoc's Avatar
snakedoc
You could look here to see if this would work they have a lot.
Mud Flaps
Old Mar 17, 2010 | 03:10 PM
stroken's Avatar
stroken
not sure where to get them, but the 05-07 dulleys have them...
Old Mar 17, 2010 | 07:00 PM
hammer65's Avatar
hammer65
These might be close.
Deflecta Shield MUD FLAPS ford F-250 SUPER DUTY 00-07 : eBay Motors (item 170447436643 end time Mar-19-10 00:12:48 PDT)
Old Mar 17, 2010 | 10:55 PM
whitesdford
Thanks guys for the links. I found some on both links. You guys are awesome.
Old Mar 18, 2010 | 03:38 AM
ron's power stroke's Avatar
ron's power stroke
i made these last year for 30 bucks a set and i just picked up stuff to make a set for the back the other day...but they was 50 bucks a set..there a little bigger...
Old Mar 18, 2010 | 03:43 PM
Bowie's Avatar
Bowie
I am also looking for mud flaps. I want the rubber ones that are somewhat flexible. I have extended flares but they just dont do the trick. Can I just some rubber material and screw them on or does someone have an idea?
Old Mar 18, 2010 | 05:49 PM
big poppa's Avatar
big poppa
I have the Ford OEM stock ones, they been fine for 4 years or so but one thing to keep in consideration, if you don't fasten them down good, they will rub the bottom part of your fenders. I know now to put something in between their like something that can cushion if you know what I mean. Here's a pic of my rear lower quarter where the OEM mud flap rubbed the fender. I sanded and coated it with Rust Bullet then will paint to color code.
Old Mar 18, 2010 | 06:56 PM
ron's power stroke
that is why i went with tread plate...they dont flap in the wind and smack the fender...gets worse with slush build up in the winter....lets not forget the 5" exhaust with a 6 " tip sticking out there right against the flap too...it gets hot enough to make the flap bend back and posably keep it kinda bent back...
Samsn4
Mar 8, 2012 03:39 PM
jejenkins417
Jun 2, 2011 11:21 AM
greywynd
Nov 30, 2010 09:20 PM
Wyatt66f100
Aug 2, 2009 02:35 PM
PaloStang
1966 - 1977 Early Broncos
23
Mar 4, 2005 04:11 PM
