climate control vacuum line size ???
Old Mar 17, 2010 | 09:00 AM
wuttrd's Avatar
wuttrd
does any body know the size of the climate control vacuum line behind the glove box? i got a tee for the a/c mod but it is to big for the oem line, do i need a reducer tee and if so what size THANK YOU
Old Mar 17, 2010 | 10:03 AM
PaysonPSD's Avatar
PaysonPSD
It's in the thread you started titled weather change a/c mod ?? See post #11.
I used vacuum line connectors with an ID size that would slip over rhe stock vac line and accept the tee.
Old Mar 17, 2010 | 10:16 AM
wuttrd's Avatar
wuttrd
line
the OEM vacuum line seems to be smaler than 3/16. the tee i got wont fit into the oem linenow that it is cut i am HOSED so to speak.thank you for the reply.
Old Mar 17, 2010 | 10:51 AM
HKusp's Avatar
HKusp
Try this, it's what SpringerPop recommends for the ESOF lines. It may work better for you.
https://www.ford-trucks.com/forums/9...ml#post8650401
Old Mar 17, 2010 | 11:18 AM
PaysonPSD's Avatar
PaysonPSD
You should be able to find vacuum connectors. They are about an inch long rubber sleeve that fit over the vac lines and the Inside Diameter will be large enough for the tee to fit in. I had the same problem and had to use a hair dryer to heat the vac line and also trim the tee to make it fit. Then I found the vac line connectors.
Old Mar 17, 2010 | 11:20 AM
wuttrd's Avatar
wuttrd
thanks guys off to the auto parts store
lazzarruss
Nov 20, 2013 09:12 PM
MarkStarr
Feb 12, 2013 04:05 PM
Marine5811
Mar 13, 2011 07:56 AM
rupejosh
Dec 15, 2009 06:05 PM
Lanny Sutton
Nov 3, 2008 09:48 PM
