Mild 360: hydraulic or solid lifter setup?
Old Jan 27, 2003 | 11:49 PM
Ratsmoker's Avatar
Ratsmoker
I think that is a very well matched setup. The cam will be nice and smooth. The carb is about perfect to feed your engine. The cam has a nice split on the durations.
Old Jan 28, 2003 | 01:58 AM
Scotty1's Avatar
Scotty1
Bigric
That cam sounds like agood one, no matter which engine you decide to build. I personally would go with a slightly more aggressive profile. but I am a go fast, high HP, and break your neck on the take off nut. I also am planning to build a Race truck so we have totally different applications.
tomw
I think you may have been reading an article about a Hydrualic ROLLER cam. Rollers whether Hydro or Solid have much steeper ramps than the non roller version. I would think that a mechanicak or solid cam would be ground slightly less agressive than a hydrualic cam. Becuase, the hydrualic has a cushion of sorts with the Hydro lifters. The mechanical or solids don't have that. But the lash in a solid cam may allow it to run a more agressive profile. As it starts up the ramp it is acctually not giving much resistence. Then as it opens the valve it may taper off more alowing for a steeper ramp, but a narrower ramp. I really don't know one way or the other I am just giving some food for thought. we could discuss the Heck out of this. If we do we need to start a new thread and give Bigric his back.
Scotty
Old Jan 28, 2003 | 06:19 AM
macguyver's Avatar
macguyver
Tomw,
I seem to remember the reading the same thing about the ramp on the solid cams starting off a little slower to take up the slack but then the slope could accelerate quicker and top off flatter because there isn't the pump up problem with solids. Could get a little more area under the curve with solids at the same lift. Not a lot of difference 'cuz they're both flat tappets but there is some. Now when you go rollers, WOW!
Bigric,
I agree. That sounds like a sweet cam. Let us know how it all works out.
Greg
Old Jan 28, 2003 | 10:01 AM
Ratsmoker's Avatar
Ratsmoker
Some interesting reading..
http://www.newcovenant.com/speedcraf...camshaft/5.htm
http://www.federal-mogul.com/speedpr...speed_pro.html
http://www.grapeaperacing.com/GrapeA...lvelifters.cfm
Cman8469
May 18, 2020 12:57 AM
murphym84
Aug 26, 2017 01:13 PM
JTB321
19
May 7, 2016 01:31 PM
scottiethebarber
Oct 6, 2015 02:36 PM
wagonerkl
26
Jul 25, 2011 10:03 PM
