What are they in?
Old Jan 23, 2003 | 09:24 PM
5x5F150's Avatar
5x5F150
Arrow What are they in?
What are the 221 and 260 engines usually found in? Are they easily located or harder to find than a dependable Chevy? Would like a V-8 with a very short stroke for a light project car,(a Porsche 914 mid-engine!) Am I a fool for wanting one of these or are they a strong engine with good potential?
Eli
Old Jan 24, 2003 | 09:32 AM
joetee10's Avatar
joetee10
What are they in?
The 221 and 260 are out of 60's fords. You will probally have a tough time finding one in decent cond, running or rebuildable. I would build a 289 or a 302. These are a little easier to find and will give you more power. Be sure to upgrade your suspension too! I once built a 76 nissan 280z with a 350 chevy and had severe rear squat problems, the exhaust would hit the ground under hard acceleration! Good luck with your project.
Old Jan 24, 2003 | 06:39 PM
Quantrex's Avatar
Quantrex
What are they in?
These engines aren't worth it except in a resto project. The small bore diameter shrouds the valves and they weigh just as much as a 302. Try this site for a short stroke, long rod small block ford setup: http://www.geocities.com/geo_42_99/281/281.htm
Old Jan 24, 2003 | 08:53 PM
Franklin2's Avatar
Franklin2
What are they in?
I believe they also have oddball bellhousing bolt patterns. I have been doing a little research on a light weight kit car, and if I had the money, the late 5.0 with aluminum heads would be the way to go.
This guy has some interesting info on his site.
http://www.angelfire.com/ar/dw42/index.htm
Old Jan 24, 2003 | 09:16 PM
Quantrex's Avatar
Quantrex
What are they in?
Yes, they had a different 5-bolt bellhousing pattern. They are most common in Fairlanes, Falcons and early Mustangs up to '65. A 302 with aluminum heads, intake, water pump and a set of headers will tip the scales just over 400 lbs. By "deburring" the block and chamfering the crank journals, you could lose a few more pounds.
