07 6.0 miss
Old Mar 16, 2010 | 08:54 PM
j-bar's Avatar
j-bar
07 6.0 miss
I have a 07 f350 4x4 6.0 that has a miss under a load out on the road and some loss of power. I have changed oil and filter and both fuel filters.It does not have the check engine light on. Any know what it might be.
Old Mar 16, 2010 | 08:55 PM
bismic's Avatar
bismic
Any mods on the truck?
How many miles on it?
Old Mar 16, 2010 | 09:00 PM
j-bar's Avatar
j-bar
Truck is bone stock.
Old Mar 16, 2010 | 09:02 PM
j-bar's Avatar
j-bar
truck has 130k miles
Old Mar 16, 2010 | 09:08 PM
bismic's Avatar
bismic
Sorry for all the questions, but the answers can help the diagnosis ...
Any smoke?
Any loss of coolant level?
Have you ever replaced the EGR valve (or cleaned it)?
Are you sure your batteries are healthy (ie load tested them)?
What oil do you use?
Have you had any recent flash updates at the dealership?
Old Mar 16, 2010 | 09:18 PM
j-bar's Avatar
j-bar
I have not changed or replaced egr valve. it has not been flashed.had to add some coolant the other day not much,only smoke that i notice sometimes at cold start and i dont let it warm up before i take off in it.oil is shell 15w40.
Old Mar 16, 2010 | 10:11 PM
bismic's Avatar
bismic
You really should get the most recent flash. There are MANY advantages (one big one is having a code thrown if the oil cooler gets plugged).
Also, you might want to look in the Tech folder and read up on pulling and cleaning the EGR valve. Also look at checking the FICM voltage.
Old Mar 17, 2010 | 06:45 AM
j-bar's Avatar
j-bar
Thanks i will do that and then i will repost the results.
Old Mar 18, 2010 | 12:28 PM
j-bar's Avatar
j-bar
I had truck in shop today hooked up and had codes run it showed #5 injector was weak.Would you replace one or all. Do you think that will take care of my miss.
Old Mar 18, 2010 | 12:54 PM
w_huisman's Avatar
w_huisman
Originally Posted by j-bar
I had truck in shop today hooked up and had codes run it showed #5 injector was weak...
What codes led you to that conclusion?
Old Mar 18, 2010 | 08:44 PM
j-bar's Avatar
j-bar
Shop just said computer said #5 was weak.
Old Mar 18, 2010 | 09:14 PM
sbowling79's Avatar
sbowling79
I've been having some injector issues myself and debating on how many to change I also have 127k on the truck. My personal opinion and my opinion only I am not a diesel tech. I would change all of them on that bank. I replaced #6 then two days later #8 went out. If I had the money I would have done them all But I gotta take the kids to Disney world next week so I had get cheap about it.
Old Mar 18, 2010 | 09:43 PM
j-bar's Avatar
j-bar
any advice as to where is the best place to buy injectors.
Old Mar 18, 2010 | 10:22 PM
bismic's Avatar
bismic
Some good choices (in order of my preference) -
Elite Diesel
Full Force Diesel
River City Diesel
Not sure about these guys, but they seem to know their stuff -
http://www.accuratediesel.com/shop/137.html
Old Mar 18, 2010 | 10:26 PM
sbowling79's Avatar
sbowling79
Bite the bullet and get them from ford. All my injectors were replaced right before I bought my truck and they were all aftermarket. Now they are failing. There are some websites that claim to sell oem parts at discount prices but I'm not sure about those.
