Removing fin fan shroud for good?
Here it is:
Fan Shroud removed... - TheDieselGarage.com
I will probably do this once the warranty runs out.
on
IMO this is not at all wise to remove the fan stator or as yall call the big plastic thing behind the fan.
That thing directs airflow around the engine. look at it you will see the pich and curve of the fins on it and how it works.
this is part of the engine cooling system. not my truck not my money but my .02
Cheezit,
I do not know if you had the time to read that whole thread. There is no argument about what you say about this being part of the "system". However there are a few guy's over there with great credentials that have been running their trucks thru Texas summer heat and over the Rocky Mountain passes with no ill effects. I put mine back in so for the time being it will remain.
Regards
Regards
on
look at the guys list of repairs 2 sets of heads. 3 sets of headgaskets... emmm ya no ill effects. Im reading it all now.
Imo not my truck. it takes 15 min to remove the fan, shroud and stator. not a big deal. no need to cut anything in half and rescrew things back together. for 15 mins of time mine will stay.
From what I read on the other forum all 17 pages it seems like the fan stator is mostly there to protect fingers from getting to the fan. There is no evidence showing it causes bad results. And about the peoples modifiications/repairs they do not specify if the damage was done before or after the stator removal.
I certainly am not an expert on this, but I am a firm believer that if one or two people can make something work reliably, then it is not just a fluke or stroke of luck.
The key point is - what benefit do you get for the risk. If you can remove the shroud and stator easily when you need to, then it probably isn't worth the risk.
on
ok so Ill post some factual information.
the op's post he states that the fan comes on now when at idle sometimes.
one of the things the stator does is directs air over the oilcooler, and the alternator.
proof: start your truck up and check for yourself.
he states that if the belt comes off going down the road hell be able to change it.
I hope so along with the fan,fan clutch, both upper and lower hoses, the nipple on the radiator too when the belt rips that off. that now $1000.00 in parts.
fact that stator does a good job containing the belt if the break... trust me on this or I have had one belt fly off while active commanding the fanvar# belt snaped and stayed were it should have in the engine bay, caused no damage to anything but the belt
I cant hear the fan come on anymore often then I did before
the fan is not an on or off device the thing is duty cycled to a percentage between 0% and 100% you cant hear it till its about 75% and at 100% you can suck up a ton of air.
it will not only help you keep your digits in tack. when the fan comes on 100% it can kick up road trash and push or pull debres up past it to only have them kicked in to the radiator or the pullies.
if you really want to know about air flow and how this works find a way to make a smoke tunnel in your garage, duty cycle the fan to 100% and vary the rpm. watch the smoke pattern.
now most of what I have listed is just pure common logic. like I said your truck your deal.
Never thought of the damage that could be done by a broken belt. Not only is that logic, but it is experience. That alone is enough for me to change my mind.
Nice input cheezit.
