02 with 4x4 problem
Old Mar 16, 2010 | 07:35 PM
408w's Avatar
408w
02 with 4x4 problem
02 F250 automatic hubs (button on the dash) Had the truck for 3 years now. 4x4 has always worked could never get 4low to work though (no light on the dash), read the truck manual and followed procedure still no go.
Today I decide to try 4 hi everything is fine get home put the trans in N and shift to 2 hi, couple of clunk sounds it goes in 2 hi...I'm curious of the sound and retry 4 hi no light or sounds drove the truck on the road as the manual states you may have to do no go. Hubs have always been in the auto position, so I try turning them to manual they turn freely all the way, dive the truck no 4wd. I have read over some of the other threads about this alot of things to try but no one replies back if they got it fixed and what fixed it. So start with fuses, relays and connections on the TC....then what? Do you have to remove the wheels to gain access to the vacuum lines at the spindle location?
Thanks in advance.
Old Mar 17, 2010 | 08:24 PM
jt371's Avatar
jt371
______
Mine has manual t-case......I'll give you a bump.
Old Jun 2, 2010 | 09:56 AM
408w's Avatar
408w
Haven't had much time to troubleshoot this problem but the vacuum lines look fine cleaned the electrical connector on the transfer case for the motor still no 4x4.?????
Old Jun 2, 2010 | 10:32 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
With the key in the on position, turn the **** to 4x4 and listen for the motor to engauge the transfer case. If you don't hear the motor, you may have to replace it.
Old Jun 19, 2010 | 11:10 PM
blakeusa's Avatar
blakeusa
What is involved in installing a new 4wd motor AND is this a common problem in these trucks. Thanks
Old Jun 20, 2010 | 08:13 PM
kupaa's Avatar
kupaa
i have the same problem but my friend at ford said its the valve or that little black box near the passenger fender is the culpret.
Old Jun 20, 2010 | 08:19 PM
JLDickmon's Avatar
JLDickmon
shoot me an e-mail..
I have wiring diagrams in PDF format
troubleshoot it
don't guess
Old Jun 21, 2010 | 12:19 AM
kbeefy's Avatar
kbeefy
thats the vacuum pump. Turn your hubs to manual and you can eliminate the vacuum as a possible problem.
fastcarz3
Feb 5, 2015 07:15 AM
robert_l_ross
Jun 5, 2011 08:50 AM
jheintze
Mar 15, 2006 10:15 AM
SMB
Feb 21, 2003 09:29 AM
harryball
May 9, 2002 10:29 PM
