More vin numbers
Old Mar 16, 2010 | 06:31 PM
66 4x4's Avatar
66 4x4
More vin numbers
These vin numbers are for my f-250 4x4. F26YC900317 ,w.b 120 , color, J , model 260 , body E-81, trans A , axle B5 , g.v.w. 06800 ,172 h.p. Thanks again.
Old Mar 16, 2010 | 07:35 PM
1965f100factory4x4's Avatar
1965f100factory4x4
well all i can really tell you off hand it has a 352
Old Mar 16, 2010 | 10:05 PM
BarnieTrk's Avatar
BarnieTrk
Here are some answers:
VIN# F26YC900317
F26 = F250, 3/4 ton, 4-wheel drive
Y = engine code = 352 V8, 2V carb
C = assembly plant code = Truck assembly plant in Ontario, Canada
900317 = consecutive build number; assembled in Aug 1966 (the last month of production for '66)
Warranty Data Plate information:
WB = 120" wheelbase; long box (LWB)
Color code: J = Ragoon Red
Model code: 260 = F250, 4x4; GVW 6800#
Trim/Body code = E81
E = Red Crush Vinyl & Red Cody Pattern Woven Plastic
81 = 81B Custom Cab.
Trans code: A = (synchronized) New Process 435 4 speed manual
Axle code: B5 = DANA (Spicer) 60 axle, 4.56 ratio; limited-slip differential;
GVW = 6,800 lbs gross vehicle weight rating, weight limit including people and cargo.
NET HP = 172 HP (208 HP as listed on the air cleaner decal is GROSS HP.)
DSO code = ???
BarnieTrk
Schickel
Aug 5, 2013 08:52 AM
Newfie999
27
Mar 28, 2012 09:17 PM
Bill W
Oct 10, 2007 12:03 AM
50th ann
General Automotive Discussion
Mar 31, 2006 11:26 PM
hdlivestock
Aug 13, 2000 08:30 AM
