need some help guys.
Old Mar 15, 2010 | 11:42 PM
whitebullet3's Avatar
whitebullet3
Customer brought truck into the shop. 2001 Powerstroke 7.3 manual. Said he had his truck plugged in and someone got water on the outlet and shorted the outlet. Later went to start his truck and it turns over fine but wont start. No WTS light and SES light is on. Hooked up my scan tool, and says communication error. All fuses are good inside cab and under hood. PCM relay is good. Diode is good. 30amp fuse is good. Tach jumps while cranking on it also. Can ya'll point me in the right direction, im a diesel tech but more of a dmax/cummins tech and dont mess with these too much. TIA!
Old Mar 15, 2010 | 11:59 PM
ldfry001's Avatar
ldfry001
you sure all fuses are good? something similar to this happened to me and it turned out to be the fuel bowl heater, so you have to unplug the heater and put a new fuse in (i cant remember which one it is) but its in the book and its located inside the cab. just a thought.
Old Mar 16, 2010 | 12:12 AM
whitebullet3
well i did unplug the heater but i didnt change the fuse, but its still good. I went over every fuse twice with my multi meter. and the owner doesnt have an owners manual for the truck. do you know of any diagrams i can find online or on here ? thanks
Old Mar 16, 2010 | 12:15 AM
Nick 99's Avatar
Nick 99
That would be fuse # 30.
Old Mar 16, 2010 | 12:21 AM
whitebullet3
okay thanks. any other ideas?
Old Mar 16, 2010 | 12:34 AM
whitebullet3
if everything checks out fine, wouldnt that mean faulty PCM?
Old Mar 16, 2010 | 08:03 AM
Action4478's Avatar
Action4478
If he has a chip, may have come loose . Make sure the key is off or batts disconnected ..
Old Mar 16, 2010 | 09:23 AM
bdrummonds's Avatar
bdrummonds
check connection of the 42 pin wiring harness at the firewall, and the 9 pin connection over the drivers valve cover.
The block heater is in no way connected to any of the engine electronics. It is a heater element with a cord. If he had GFCI breakers on his house they would have tripped with the water on the plug. Worst case scenario the plug or the cord melts.
Old Mar 16, 2010 | 11:39 AM
whitebullet3
alright thanks guys I'll check those
Shogun6
May 7, 2013 01:57 AM
Truck Guy99
Escape & Escape Hybrid
Apr 1, 2013 07:44 AM
JSolve
Feb 10, 2013 05:21 AM
2020
Aug 5, 2012 08:09 PM
claycomotrucks1991
Dec 27, 2009 10:06 AM
