53 F100 Voltage
Old Mar 15, 2010 | 06:17 PM
BHump91's Avatar
BHump91
53 F100 Voltage
I need to get a battery on a 53 F100 v8 and I was wondering if it was a 6 volt or 12 volt system. Is there any way to check or were they all 12 volts?
Thanks
Old Mar 15, 2010 | 06:21 PM
larryb346's Avatar
larryb346
Your 53 started life as 6 volts. To find out what it is now you need to look at the generator and coil and see what voltage they have stamped on them. Also the voltage reg.
Old Mar 15, 2010 | 08:17 PM
BHump91's Avatar
BHump91
I couldn't find any stamps on the generator and the voltage regulator was too worn too read. I took a couple pictures though. Can anyone help identify if its a 6 volt or 12 volt system by looking at the generator?
I can get a picture of the regulator too if that helps
Old Mar 16, 2010 | 12:51 AM
Julies Cool F1's Avatar
Julies Cool F1
Two simple things will give it away. Take a look at the battery that's in there. If it has 3 holes with caps, it is 6 volt. If it has 6 holes with caps, it is 12 volt.
Also, if your GROUND cable is run off the POSITIVE (+) battery post, it is a Positive Ground system and is 98% sure to be 6 volt. If the GROUND cable runs off the NEGATIVE (-) post of the battery, it is most likely 12 volt.
The other end of the GROUND cable will bolt directly to the frame of the truck or to the engine block.
jhaas63
Sep 30, 2012 10:33 PM
HkyswiM
Nov 16, 2011 04:24 PM
97F250LD
Aug 15, 2005 09:49 AM
Narwhal
Nov 27, 2003 09:59 AM
TomNE
Nov 3, 2002 12:26 PM
