Snowmobile Question
Old Jan 23, 2003 | 05:34 PM
Longneck's Avatar
Longneck
Snowmobile Question
I just got a snowmobile from a guy who hasn't even started it in almost 2 years. I got it going and it seemed to run alright but it was just sitting around with fuel in it for 2 years. Is there anything I should add to the new gas to help clean out the carbs?
Longneck
Old Jan 23, 2003 | 05:59 PM
Mil1ion's Avatar
Mil1ion
Snowmobile Question
Welcome to FTE!
You might try searching in this forum for snowmobile threads and posting to it rather than waiting around for the snowmobilers to show up.
There are also many snowmobile related web site's too.
Old Jan 23, 2003 | 06:26 PM
Waxy's Avatar
Waxy
Snowmobile Question
Nothing you can add to the gas will clean out the carbs. They have to be removed and cleaned by hand. That means every jet and tiny air passage. There are proper tools for this, but if you don't have them, let the carb soak in some parts cleaner and used compressed air.
The fuel pump(s) should also be inspected and cleaned, new rubber seals are good preventative maintenance.
The most difficult thing to inspect, and unfortunately the most expensive possible failure, is if the crank seals are dried out and allowing air into the crankcase. This will cause a complete melt down within a couple miles. Run a little pre-mix oil in the gas for the first half a tank, it's about all you can do short of a major overhaul.
Give me some details on the year and model of the sled. I should be able to answer just about any question you've got.
Waxy
Old Jan 23, 2003 | 06:35 PM
Nutter's Avatar
Nutter
Snowmobile Question
Hey Longneck! Try www.snowmobilefanatics.com it's a great source of info for all brands and topics on snowmobiles
Old Jan 23, 2003 | 09:33 PM
Fordzlla's Avatar
Fordzlla
Snowmobile Question
It all depends on how it was stored.
Fuel stabilizer is a great thing, it will clean out sludge and carbon on two strokes.
Ask the P.O if the engine was fogged and either the float bowls drained or fuel stabilizer was added to the tank before storage.
It's always a good idea to run lots of isopropyl gasline antifreeze, as the smallest amount of water can plug a main jet and vaporize a piston.
If your machine runs ok, I'd just change the fuel and oil filters, lube the clutches, grease the chassis and run it.....
Maybe avoid the high speed lake runs till you have run a few tanks of fuel through it.
I just got my sleds out after a very long time in storage (30 miles on one last year, 0 on the other) All I did for service was to clean the dust off and put on a coat of wax.
Of course they were serviced and stored properly with fuel stabilizer and everything lubed before storage.
Old Jan 24, 2003 | 08:21 AM
Longneck's Avatar
Longneck
Snowmobile Question
Thanks guys,
I knew you would know about anything with gas running through its veins. The sled is nothing fancy, it is a 1992 Phazer Longtrack. Dual carbs, pretty light and responsive. I needed something to get me out and back when I go ice fishing. Maybe I will do a little work on it before I venture out to far though, he had it stored with out any fuel stabilizer so I am going to see if it gummed up the carbs this weekend.
Longneck
Fuha
36
Jun 6, 2012 10:24 PM
ghunt
May 8, 2011 08:16 PM
websthes
19
Jul 7, 2009 12:39 PM
78bigunns
13
Apr 20, 2006 02:31 PM
preppypyro
Nov 28, 2005 08:01 AM
