changing carb
Old Mar 15, 2010 | 04:26 PM
stormdraconis's Avatar
stormdraconis
changing carb
Okay 4180 holley leaks at accelerator diaphram tired of dealing with it. Changing to an edlebrock 600 cfm electric choke 85 ford bronco is what its going in. What extra item would I need? If any beside the accelerator kit. Where is the best or easest location for hot wire on choke. How much adjusting if any need to be done. I think everything is factory spec automatic trany.need to know what hoses to get rid of on emmissions crap so I can have less of a snake pit of hoses. On emmissions I don't have to worry about car is 25 yrs old just tring to keep it alive long enough till I'm able to get it rebuilt and still get it leagal
Old Mar 15, 2010 | 06:24 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
On a stock truck you're better off rebuilding the carb that's on there now, but if you're bound and determined to change it...
I used a throttle cable bracket that's held down by the driver's rear carb nut. It's got an allen head adjustment screw to maintain tension. I also used a Lokar kickdown cable to make everything easier.
For the choke use the stator terminal on the alternator (best) or the hot wire to the coil (everyone seems to do this).
Barty88
Nov 4, 2009 08:48 PM
1999XLT
32
Jul 25, 2008 04:09 PM
urcysk
Apr 4, 2008 10:35 AM
pablocruz69
Jan 5, 2007 06:49 AM
1999XLT
Sep 15, 2002 07:21 PM
